Brake adaptor issue...
[Closed] Brake adaptor issue - help!
5 Users
I just tried to fit an IS magura julie caliper to an IS fork mount with a 160mm disc - but it didn't work. Disk only makes contact with around 1/4 of the pad.
What was I doing wrong? Could the fork mount be for 180mm rotors only? If that was the case, can you get IS-IS Front 160mm adaptors?
I've tried running a 185mm avid disc too - but it rubs on the caliper body. Because its IS i can't use the conical bolt kit.
Any thoughts?
Posted : 19/04/2011 4:26 pm
What fork?
Sounds like you need a 180 rotor?
Posted : 19/04/2011 4:28 pm
As above, sounds like a 180mm set-up
Is the caliper actually post mount with an adapter fitted (like this)?
If it is then you just need a 160 front adapter (not a 160 rear) or use the current adapter with a couple of washers to space it out enough for the 185 rotor... or buy a 180 rotor
Can you post a pic?
Posted : 19/04/2011 4:36 pm
Its an on-one steel fork. Its straight up IS, no adaptor fitted. Think I either need some washers, or a 180mm rotor. Oh well, 160mm would have been nice.. 😐
Posted : 19/04/2011 4:55 pm
IIRC mine took an IS mount XTR caliper with no adaptors and a 160mm disc.
It sounds like a rear caliper on the front.
Posted : 19/04/2011 4:58 pm
IS to IS no adaptor is needed or used - you get the right size disc for your caliper probably 180. IS calipers can come in different sizes for different discs - hope certainly do so you don't need an adaptor
Posted : 19/04/2011 5:12 pm
