Hello
So my friend has this commuter bike with the Bosch cx 4 motor and intuvia display.
She got a new rear wheel fitted, and a new cassette fitted, and now it won't show
kilometers, and shifting to lower gears it only assist for some seconds, and then shuts of.
As far as I know their is no sensor on the rear wheel...? .. so it should not matter that the rear wheel has been changed, and a new casette mounted with a different gearing.
Thanks
Don't all Bosch motors need a magnet either on the spoke or the disc?
Sounds like its missing the magnet or its not aligned on the wheel to pick up on the sensor.
I'd be going back to whoever fitted the rear wheel
I fitted it .... !
but I looked closely at the old wheel... could not find a magnet!
Definitely has a magnet… that’s how they work!
There should definitely be a magnet. Did you swap the discs or fit a new disc?
oh man I did swap the disc..... Thanks doomanic!!!!
jeb
I fitted it …. !
but I looked closely at the old wheel… could not find a magnet!
Blame "standards" and claim you "figured out a way to make it work" - you are still the hero 🙂
It could have had a Shimano Steps disc on the old wheel and the magnet is not that obvious as it’s quite close to the centre. Defo needs a magnet though.
oceanskipper, I found it sitting on a round plastic dingy on the old disc, so now i will try to transfer it, so mystery sorted!
There are other types of magnets available if you are using either 6 bolt or center lock.
Centerlock magnet -
The pic is the 6 bolt one. I'm changing my wheels from the stock cheap shimano to hope pro4 and the originals are centerlock, the pro 4 are 6 bolt, so i needed a different magnet.
Thus
HA! .... the magnet from the old wheel sitting on a round plastic dingy, cut the magnet out and ziptied it on the new 6 hole wheel 🙂
