BOS Deville DIY ser...
[Closed] BOS Deville DIY service/parts
5 Users
Morning all,
Been looking for somewhere that gives instruction on servicing and supplying parts for BOS deville 150mm forks.
The forks probably just need a service so was after some new seals/oil etc.
I've tried their site but it appears to be down. http://boutique.bosmtb.com/
Any pointers?
Cheers!
stu
Posted : 09/02/2017 9:08 am
James at J-Tech can probably provide some guidance. I'm not sure if he sells parts aftermarket* - but he has serviced mine using SKF seals etc...
*Edit: Appears he does. I think the Fox 34 ones fit.
Posted : 09/02/2017 9:25 am
SKF seals are what most people use I do Deville servicing used to do all servicing before Jungle became the Distributor of BOS.
Posted : 09/02/2017 10:15 am
I needed a PDF of the void manual last week, with the website being down used the facebook page. Wasn`t the quickest of response times but they sent me the manual.
Posted : 09/02/2017 11:13 am
You can buy oil and seals direct from Jungle (the UK distro) here http://www.jungleproducts.co.uk/shop/cat/bos/41
Posted : 09/02/2017 12:05 pm
