ok here we go Ebike content
my Trek has the sram EX 1 drivetrain it is 20 months and about 1000 miles ish
the hugely expensive cassette has started to act up mostly on the middle cog which I guess i must use lots .
now I dont want to spend £350 th £400 on a new cassette when 6 of the eight cogs are still in good nick .
30 years ago we used to split cassettes and pop in new or old cogs to make do and mend .
I have seen a sram 8 speed cassette on wiggle for £15 so wondered if it was splitable and worth a try to bodge up the EX 1 cassette
so will the cogs fit the freewheel. I guess I wont die doing it and if it fails then I have only wasted 15 quid
11-48t, 8-speed cassette machined from case-hardened tool steel
It's machined so it will be one piece from steel, Is there wear on those cogs? is it obvious or is it a setup/mech issue?
