Best freewheel that...
[Closed] Best freewheel that isn't a WI?
10 Users
Are there any reasonably-priced freewheels out there that don't sound like a coffee grinder after a minimal number of miles? I'd be reluctant to go with Shimano again as the last one died after a couple of months. Currently using an ACS but apparently there's an ultra-cheapo variant of it which dies quicker, which is the one I have, and its days too seem numbered.
Posted : 18/03/2010 8:52 am
Ahem... Proper cassette wheel with spacers and single sprocket.
Or if you're silly enough to use a SS specific wheel which offers no real advantages then WI seems to be the best out there and even they don't seem to be even close to as reliable as a cheapy cassette wheel.
Posted : 18/03/2010 8:55 am
Got one you'd like to give me then smartarse? 😉
Posted : 18/03/2010 9:01 am
No but there'll always be some numpty on here who'll buy a SS wheel or even just do a straight swap 🙂
Posted : 18/03/2010 9:03 am
Unlikely, bearing in mind it's a v-brake wheel. With a noticeable dent in the rim. I'd need to buy an SS converter kit too. Come on, more suggestions! 🙂
Posted : 18/03/2010 9:19 am
Posted : 18/03/2010 9:20 am
[url= http://farm4.static.flickr.com/3564/3790009930_72af6b4069_b.jp g" target="_blank">http://farm4.static.flickr.com/3564/3790009930_72af6b4069_b.jp g"/> [/img][/url]
Posted : 18/03/2010 9:23 am
Can you get one of those that isn't a gopping colour? 😉
Posted : 18/03/2010 9:29 am
SSS, that a titanium sprocket?
WWAAAAAAAANNNNNTTT
Posted : 18/03/2010 9:32 am
freegan bikefascist - Member
WWAAAAAAAANNNNNTTT
It's a Boone Ti cog.
If you find anywhere that still has some for sale let me know. 😉
Posted : 18/03/2010 9:34 am
 Del
if i may - 'bo11ocks sir'. i've just replaced a White Industries freewheel that's done 4 years, one bearing changed, no other maintenance. that's doing a bare minimum of 25km, and 800m rise and fall per week, most weeks twice that, some weeks three times.
if you already have a ss wheel then the WI is the way to go IME.
Posted : 18/03/2010 10:27 am
Just killed my second WI in just under 4 years, so averaging just under 2 years each, doing pretty much the same riding as Del. In the past I've tried several ACS, Shimano, and something called AC Racing, and killed all of them in under 2 months. The Dicta thing that came on my inbred was even worse.
Cassette hub and sprocket is the only realistic alternative IMO, but I would say that a WI is equally reliable and durable. I've killed Shimano freehubs on geared bikes in less time than my WI freewheels have lasted.
Posted : 18/03/2010 10:39 am
my hope pro 2 ss had a new set of springs this year . after 5 years abuse .....
i make that 1 set of 10 pound springs in 5 years.
does alot of miles a year
the shimano freewheel on my commute hasnt turned a mile - yet its ****ed
Posted : 18/03/2010 10:45 am
+1 for the WI, cheap ones don't come close.
Mine's already outlasted three or four Shimanos so I figure its paid for itself. Cheap SS freewheels are a false economy, and I know what I'm talking about when it comes to false economies and bike parts!
And it makes a lovely sound.
Posted : 18/03/2010 11:11 am
You may say it but since what I posted is exactly what my experience is, you're wrong. Of course I could have seen a completely statically unusual set of results (eg all other WI freewheels last forever) but I'm inclined to believe that's not the case.
I am happy though that yours is much better than the three I've seen die within a year 🙂
Posted : 18/03/2010 11:23 am
Tensile freewheels? or other trials type freewheels.
Some of them only available in 18t though.
http://tartybikes.co.uk/search.php?category_id=16
Posted : 18/03/2010 11:28 am
 Del
obviously i have insufficient data.
i only killed mine after i broke a tooth off, and also allowed it to run for a goodly while after i should have changed out the bearing. could probably still run it now if i hadn't done that, but i'd killed a strong chain too, so it just seemed like 'time', and i had a spare.
how did those die?
Posted : 18/03/2010 11:53 am
Seizing/slipping
Posted : 18/03/2010 12:50 pm
 Del
hmm. well, if they're still around, and the current owners don't want 'em, i'll have 'em.
Posted : 18/03/2010 12:52 pm
