Beginner inner tube...
[Closed] Beginner inner tube question - presta v schrader
5 Users
 j2b2
Hi
How do I know if my bike takes presta and schrader inner tubes?
https://www.decathlon.es/bicicleta-de-montaa-btwin-rafal-740-id_8314897.html
Wheels are Mavic Cross Ride and tyres are Hutchinson Python.
Last time I reckon I bought presta inner tubes, but schrader look a lot cheaper in Decathlon.. is there much of a difference with reliability?
Cheers.
Posted : 20/06/2017 9:12 am
They look like presta...haven't noticed a price difference. They all hold air...untill they don't.
Posted : 20/06/2017 9:17 am
Schraeder valves are a bit bigger diameter. It's [i]possible[/i] they your rims are drilled only to fit Presta (or they may have a plastic collar fitted to reduce a Schraeder size hole).
Still, you probably own a drill, right ?
Posted : 20/06/2017 9:27 am
Presta - you press them to let the air out.
Both work as innertubes, but if your rims have a small hole in them, only Presta will fit.
Posted : 20/06/2017 9:59 am
Valves:
I suspect you'll have presta valves but may be wrong. Personally, I prefer presta anyway, in fact, buy presta as they'll definitely fit, Schrader may or may not as they need a larger diameter hole.
Posted : 20/06/2017 10:01 am
