Bash Ring Size Sele...
[Closed] Bash Ring Size Selection
4 Users
Hi chaps
Can anyone advise me on how to shop for a bash ring to replace my 44T chainring (FSA Alpha Drive 44x32x22T) ?
Not sure what I am looking for to be honest. It needs to have four bolts and I am guessing that I need to buy a size that is bigger than the 32T? Is the BCD of the bolt pattern standard across all four bolt rings that fall within a certain size?
Any info and recommendations would be very much appreciated.
Thanks! 🙂
Posted : 28/11/2012 11:28 am
http://bbgbashguard.com/tech.html
Posted : 28/11/2012 11:36 am
You need to buy the same size as the ring you're covering, not the ring you're replacing. The 2 outer rings generally have the same BCD, and the inner is smaller.
Posted : 28/11/2012 11:38 am
Cheers guys. All is clear.
Posted : 28/11/2012 11:41 am
get a 32t bash
Posted : 28/11/2012 11:42 am
