Avid Code HELP Plea...
[Closed] Avid Code HELP Please!
3 Users
I've searched the web in vain so now I'm hoping for a bit of help from the collective knowledgebase here!
I need a spare pad retaining bolt for a set of '08 Avid Code disc brakes. I've rounded my front on in a fit of temper so will need to drill it out and get a new one before I have to change my brake pads!
I'm stuck out here in Spain so can't just pop into a friendly local bike shop either so was hoping for something off the web.
Any help would be really gratefully recieved!
Posted : 14/03/2009 10:41 am
is this any good to you: [url= http://www.sram.com/en/service/avid/view.php?catID=1&subcatID=8 ]SPARE PARTS LIST[/url]
Posted : 14/03/2009 10:45 am
I saw that, cheers. It's this that I need I guess: 08 Code Caliper Spare Parts Kit Qty 1 Caliper (Code & Code 5) which has loads more than I actually need and I guess is going to cost a fortune!
Any ideas where I can get it though? I can't find it on the web anywhere.
Posted : 14/03/2009 10:51 am
you need the part number, then you could try these guys:
Spain
Motor Dealer
Europolis, calle Lisboa , 12-14
28231 Las Rozas Madrid
PHONE: +34 91 637 70 97
FAX: +34 91 637 72 64
EMAIL: info@motordealer.com
WEB: www.motordealer.com
They are the Distributors if you have no luck with a bike shop, they may be able to direct you to a shop that would hold stock?
Posted : 14/03/2009 11:49 am
doug_basqueMTB.com - Member
did you get anywhere finding these bolts, I really should get one for my rear calliper ???
Posted : 06/08/2009 12:02 pm
Wow, that's an old thread! I went for the bodge effort and hammered a torx key into the pin and eased it out. I've changed the pads a few times since and the torx key fits in nicely! You've just reminded me that I really should get the proper part.
Sorry that doesn't help you much.
Posted : 06/08/2009 12:17 pm
Yer, that's exactly where I am right now 🙂
Posted : 06/08/2009 12:27 pm
