Anyone ridden the M...
Anyone ridden the Mojo Nicolai yet?
Blake how long have you had the bike mate?
I'm intrested in the issue youve had with the back end getting a bit squirrelly. Was it the first time you'd ridden it in bad mud or wet?
I'm not digging your riding at all I'm just interested if with so much weight over the front now the back can get loose on the Bike without giving you any signals it's in its way to full "widow maker" ( to quote Chainline!!) .
Good news it feels better though mate nothing worse than one of those out of nowhere stacks, totally screws your head for a while.
Posted : 12/11/2017 11:18 pm
I was trying to figure out the height then I went back and saw the tyre change.
Mine is 350mm with 2 offsets but only with 170mm.
BlakeC are you running 155mm 216 shock in the 222 setting? I get 350mm (approx) BB in that config with no bushes and a 2.35 MM front with 2.4 Morso rear on 30mm internal rims.
That's my preferred config.
Posted : 13/11/2017 10:36 am
Wookster
About 3 months. Initial thought was to keep the same tyres as the old bike. To learn the characteristics of the new bike while having something familiar.
The crash was on south down chalk on the fire road going from one wheel track to the other. It probably was it first ride on wet chalk where it was properly wet rather than just damp. You could be right in I haven't adjust my style to the new weight distribution.
Chainline
Yes running the 216 shock in the 222 position.
I'm going to put the old tyres on again and remeasure the BB might be my rims are to narrow for my tyre choice.
Posted : 13/11/2017 12:32 pm
blakec 350mm is good, you can alwys adapt the dynamic sag with volume spacers and damping to give you the right height, but 350 with two offsets will give some angle compromise if already in the 222.
Posted : 13/11/2017 1:30 pm
Chainline
Unfortunately I am already at max psi and spacers due to weight.
Posted : 13/11/2017 1:43 pm
South Downs chalk is a shit regardless of what tyre or bike you're on I have a hang up about deep ruts from a stack in the Downs chalk roads!!
Posted : 13/11/2017 2:24 pm
Chainline what are your thoughts on the 40s on a 170mm 29er? There seems to be a bit of a delay on the parts for the 36s which has given me too much time to think. From what I remember you're running a 29 wheel in the 650 40s?
Posted : 13/11/2017 2:32 pm
I was running a 40 with a 29 front. Have swopped to the ebike chassis for testing purposes and am about to start testing a couple of new products....
So have a set of 40's I need to sell.
40's are dreamy. Best fork I've ever used, full stop. The extra weight I never noticed (400g in reality) The sensitivity is stunning. Loads of room with a Shorty front. enough room with a MM 2.35.
The caveat being if you live in a muddy area the arch clearance is restricted.
Also the 51mm offset is less good on a 27.5 in my opinion below 61deg. This is not an issue on a std GeoMetron with a 29 wheel.
Posted : 13/11/2017 4:04 pm
I live in Ireland which is definitely a muddy area. I had assumed Fox had a 29er 40 out now but it doesn't look like it - I'd be put off by clearance issues, I hardly ever take the D-Fender off my 36s.
Posted : 13/11/2017 5:34 pm
Would any owners describe theirs as playful? Is it more speed and steamroller? I've been reading the thread for a while and get the impression that they climb better than expected and descend fantastically but is it all about speed or is there a bit of character. I did loose track a bit over the variations and mods though, so it's a broad stroke impression.
Posted : 13/11/2017 5:41 pm
You really need to try one, set up for you.
Posted : 13/11/2017 6:07 pm
YoKaiser. That also depends how big you are. If you size down, to 'recommended' and have the suspension set up playful, then it can be playful. Sizing down doesn't mean it's small and there is no compromise on angles.
For example the NotSoLong that I showed on here is my daughters bike/small persons recommended bike.
600mm ETT, 350mm ST but 465mm reach. Thats longer than my Helius of 2010. When I ride that it feels like a Bronson to pedal but an XL hightower out the saddle in terms of reach but I'd describe that as crazy playful.
So kind of what Shandy said. Especially in terms of size if 'playful' is an important factor trying is key.
I can easily ride the Long/S and it feels very small to move about but compared to other mainstream equivalent sizes is rather long on paper.
Posted : 13/11/2017 6:21 pm
I think some people get on with longer chainstays and some don't. I know a lot of people find 430mm 'playful' but for me the bike is better balanced and more fun with longer chainstays. That's one of the reasons I would always say to demo one if somebody was unsure.
Posted : 13/11/2017 6:49 pm
Shandy - Member
I live in Ireland
That's three in the country that I know of, then. We're only a few short of an owner's club over here. 🙂
Posted : 13/11/2017 7:36 pm
Thanks for the replies, some stuff to mull over.
Posted : 13/11/2017 8:31 pm
Anyone local to Sheffield is welcome to try my Longest G16. I try to get out and about most Sundays.
It's still in it's standard out of the box set up. No messing with chainstays or bushings or anglesets yet.
It depends what playful means. It's certainly not a joyless, XC style, exercise bike. My idea of playing is crashing into the roughest stuff I can find and hitting jumps. For that stuff, so far, it seems perfect.
I've got it set up quite progressive so it doesn't sit too low in the travel and it has plenty of pop in tight berms and switchbacks. So far I'm not missing my hardtail or my DH bike so I've successfully replaced two bikes with one which was the original plan.
Posted : 13/11/2017 10:39 pm
Just to note changing chainstay length requires a new insert for those that may not realise.
Posted : 13/11/2017 10:51 pm
A nicer picture of mine 🙂
Posted : 14/11/2017 2:02 pm
Any of you that have e-mailed Mojo direct not had a response? I assumed they might be busy with some of the stuff going on but did think I'd get a reply. Despite looking at many many other bikes I keep coming back here....
Posted : 17/11/2017 7:17 pm
They have been very busy but it may depend on the mail addeess used.
Mail me (address in profile) and I’ll give you a direct address and make sure Paul gets in touch.
Posted : 18/11/2017 9:52 am
email address: http://geometronbikes.co.uk/Contact.html
Posted : 18/11/2017 9:59 am
I'm looking at buying a g16 as I'm really struggling with lower back pain on medium Canyon Strive.
Does anyone know if the much steeper (74.5 vs 77) seat angle and longer reach (458 vs 502) will help the lower back on the climbs?
I'm 5ft10
Posted : 18/11/2017 4:36 pm
My back definitely suffers less since I got longer bikes.
Posted : 18/11/2017 7:20 pm
 duir
I'm 5ft10
I take it you have fiddled with seat position/type? This can make a huge difference to lower spinal pressure. If you are looking for a more stretched out position you may be quite surprised by the Geometron. The combination of short stem and steep seat angle makes for a pretty upright seated pedalling position and I find the extra reach is more noticeable downhill.
That said I have suffered dreadful back pain over the years which I put down to poor geometry but I do not get back pain on my Geometron.
Posted : 18/11/2017 7:48 pm
Won’t a longer bike pull you forward and stretch your back more?
Posted : 18/11/2017 8:34 pm
The back pain esp the lower back is from being hunched over the the hamstrings get tight and whammy! Longer bikes for me make a massive amount of difference and effectively stop this tightness and pain.
Posted : 18/11/2017 8:43 pm
The riding position also helps the hams on the GeoMetron due to the steep seat angle. One of the reasons tri bikes have steeper angle to reduce tightening/shortening and improve the run.
So yes it may help you. As other s have mentioned it was a welcome side effect for me too.
You could try pushing the saddle forward to achieve this effect on your canyon as a test to give you an idea. You will immediately notice a different balance of muscles being engaged in pedalling.
Posted : 19/11/2017 11:36 am
Alot of lower back pain during cycling is from flexion of the spine, so being hunched over on a shorter bike doesn't help. I ride a longest G16 im 6'2 wth long arms. I recently rode a XL yt Capra my back ached for days after.
The G16 allows you to hold a straight line spine as your hands are further in front of you. When your back is arched on a shorter bike this creates Flexion of the lumbar spine ie arched lower back as such on shorter reach bikes this pulls on your Psoas and Iliacus muscle which is already working hard from lifting your leg up each time.
What I also noticed from riding the Capra was how hunched and harder to breath whist riding it was. I was then raising my head further to look ahead on the trail and noticed how much my traps and neck muscles where working ie resulting in a sore neck.
I used my 2016 G16 to a 24hr solo mountain mayhem, because the body position was so much better than any thing I had tried other wise. I didn't get a sore back or neck at all during that race.
It amazes me how this style geometry is getting used more in XC.
Posted : 19/11/2017 3:03 pm
Paul - Thanks. You sound like you know what you are talking about!
I saw an osteopath the other day and he said that I have hypermoblity in my joints especially in my spine.
Therefore arching my back while riding only makes it worse and totally exhausts my back muscles. I've also got the tightest hamstring and psoas you can imagine.
I'm hoping the extra room on the Nicolai will give me the space to straighten my back and relieve the pressure.
Posted : 19/11/2017 9:00 pm
 edd
After some time watching eBay and pinkbike listings for the right frame to come up, I finally bought a 2016, long Geometron frame today. Can’t wait to get it built up and on the trails.
Posted : 23/11/2017 7:25 pm
Nice one Edd! Loki g forward to seeing the pics!!!
Posted : 23/11/2017 7:30 pm
Top job edd
Posted : 25/11/2017 12:40 pm
are all the new 27.5 Geomotrons boost back ends now?
Posted : 25/11/2017 12:41 pm
I've got a complete longer bike for sale if anyone is looking 2700 with hope throughout.
I've got a long as well and bought this to try out upsizing but prefer the long after some time spent on both.
Posted : 25/11/2017 1:54 pm
Nickc yes. But with an 83mm BB. So no boost crankset required but need an 83mm B.B. compatible crankset.
Posted : 25/11/2017 4:20 pm
Chainline - Member
What was the logic behind that one? Seems odd to push the chainline out further, 1x tends to benefit from narrower chainline if anything.
Posted : 25/11/2017 4:56 pm
I'm going to guess it was for better tyre clearance and more space between the swingarm bearings = stiffer and more durable
Posted : 25/11/2017 5:40 pm
Do you mind telling me how tall you are steveh?
Posted : 25/11/2017 5:42 pm
 edd
One of the reasons that I waited for a 2016 one (which has a 73mm BB) to come up for sale was that I didn’t want a 83mm BB. The 83mm BB limits the cranks that you can use.
Posted : 25/11/2017 6:28 pm
Anyone in Scotland got a G13? Mojo haven’t replied to my enquiry but I’m still curious about the bike. Unlikely to go way south for a demo but if any kind STWers had one I could swing a leg over that’d be really useful.
Posted : 25/11/2017 8:25 pm
Groundskeeperwilly if you msg me your details I’ll give Chris/Paul a nudge.
Posted : 26/11/2017 1:21 pm
steveh - Member
Bloody hell that sold fast , anyone on here buy it ?
Posted : 26/11/2017 3:40 pm
It was for bearing spacing and clearance. We figured there were enough 83mm cranks out there and the benefits outweighed downsides.
Posted : 26/11/2017 11:23 pm
Hi all. Just to let you all know that, having suggested it myself once already, along with seeing a number of request from other posters on this thread, I have created a Facebook Group for Mojo Nicolai Geometron Owners. Please join and post your rides, technical questions and share your passion for all things two wheels!
Posted : 10/12/2017 11:21 pm
 edd
Any advice on routing the hose for an XT brake with 180mm rear rotor?
Posted : 10/12/2017 11:40 pm
Page 37 / 48
