Got some new bearings from KaTec (very good service). Now I'm stumped as to how to get the old ones out. Had a serch around, but can't find anything definitive. Anyone got paperwork from SS?
Instruction are here
[url= https://docs.google.com/open?id=0B382x_6sspHCNkpZMlJfVTJzR0U ]Switch Evo Front Service[/url]
[url= https://docs.google.com/open?id=0B382x_6sspHCRUJDeGV4cTJOOG8 ]Switch Evo Rear Service[/url]
[url= https://docs.google.com/open?id=0B382x_6sspHCdDVzZnVCNENacmM ]Superstar hubs bearing list[/url]
Brilliant, thanks.
Sorry for hijack! Where it says tool inserts here, what tool is it referring to? I'm having trouble removing the "seals" under the adaptor caps..
Sam2391 - I ended up just taking the wheel into my LBS, I didn't feel confident changing the bearings myself, I could see things going horribly wrong and the whole thing becoming an expensive mess.
I did do a bit of research though, it seems that unless you're able to manually pull the bearings out with your fingers, or drift the bearings out using a screwdriver (by tapping gently around the edges so that it slowly comes out - the only other option would be to use a specific bearing drifting tool. I found a youtube video shows the different methods.
