alternatives to GT8...
[Closed] alternatives to GT85?
10 Users
Run out of GT85 and the chain on the cross bike is looking pretty forlorn, its an ss so gets dumped after rides but was going to get some more GT85 to give it a skoosh, wipe and a lube after rides to keep it healthy for longer. Anything else worth trying? I had thought maybe just get a park tools chain brush and use some bike cleaning pedros stuff i have lying about but never been that thrilled with
ta
Posted : 06/04/2010 6:23 pm
TF2 spray seems to be pretty much the same thing. Doesn't smell as nice.
Posted : 06/04/2010 6:51 pm
use actual chain lube perhaps?
Posted : 06/04/2010 7:03 pm
Try cleaning it properly & then using a decent quality lube, something from the likes of Finish Line, Motorex, Fenwicks, Green Oil etc.
Posted : 06/04/2010 7:06 pm
If it's a ss why not use the thickest gungiest chain gloop you can get your hands on?
Posted : 06/04/2010 7:11 pm
TF2 seconded.
Posted : 06/04/2010 7:37 pm
Why would a bike being a ss mean you would use any lube other than what you use on a geared bike? The chain does the same job in both situations...
Posted : 06/04/2010 7:43 pm
ok perhaps i didnt make myself hugely clear-chain always lubed with finish line wet BUT after a ride I normally blast it with GT85 wipe it down and lube it. For me the only difference with ss is that it's a pretty quick job so GT85 is pretty handy, sqoosh, wipe and lube.
Ill have a look at TF2 cheers
EDIT: oh its a lube 🙁
anyone tried [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=14885 ]this[/url]?
Posted : 06/04/2010 9:02 pm
There's loads of TF2 products, the one I'm thinking of is an aerosol and it's basically just another stoddart-solvent-in-a-can doofer with some additives so they can pretend it's not just just white spirit 😉 It's a lube but only in the same way GT85 is.
Posted : 06/04/2010 9:31 pm
Dont use TF2 it smells horrible!
GT85 all the way 😀
If you want a part used can of TF2 let me know
Posted : 06/04/2010 9:41 pm
Do you leave the chain to dry before lubing it? as GT85 will break down chain lube if you apply the lube while the GT85 is still wet. Ideally the solvent from the GT85 needs to have evaporated off before applying the lube.
If you're stuck then just apply some chain lube and wipe off while still wet, should take most of the crap from the outside of the chain with it.
It won't have cleaned the grit/mud from the inside of the chain, which is the important bit.
Posted : 06/04/2010 10:10 pm
interested in the half used TF2!
wipe down the chain after using GT85 and try not to aim it at the limited lifespan shimano grease in the bb cups 😉
Posted : 06/04/2010 10:41 pm
I love the smell of GT85 in the morning.
Posted : 06/04/2010 11:07 pm
