Hi Folks,
A bit of a random one ....... do any of you know if the Alfine // Nexus range of IGH share the same cable pull ratios?
I appreciate an 8 speed shifter won't give you the 11 options of an 11 speed shifter but would/should an 8 speed shifter work with a 4/5 speed hub.
The limitation, like with a derailier, is at the hub end so in theory is the cable pull is the same the shifter will just stop.
I'm looking to add a trigger to replace the cumbersome 4 speed twist shifter brake combo on a bike.
Thanks for looking - if you have 😉
M
Not sure but Microshift might do a compatable trigger shifter. I brought a 7spd Nexus bike back from Denmark that my sister in law now uses. It was only later that I noticed it was a Microshift not Shimano shifter.
Sheldon may have the answer in the links below? Report back.
https://www.sheldonbrown.com/nexus-mech.html
https://www.sheldonbrown.com/cribsheet-IG-cable-pull.html
nexus and alfine 8 spd certainly are
tjagain
Full Membernexus and alfine 8 spd certainly are
This is the sort of encouragement I'm after - thank you TJ.
I'm hopeful an 8 speed shifter will shifter the 5 gears of my Nexus hub.
that I wouldn't bet on
Di2?....
https://www.freewheel.co.uk/shimano-nexus-sg-c7050-5r-internal-hub-gear-for-di2-5-speed-varsgs70505
Don't know if these guys might know (site not updated for ages).
https://hubstripping.wordpress.com/
Nexus and Aldine 8 are compatible.
Aldine 8 and 11 are not, and the pull is reversed too, I think.
One pulls from hi to low, the other from low to high.
I think.
