Air Pikes losing tr...
[Closed] Air Pikes losing travel
[#1644575]
Why, and how can i get my 15mm back?!
Posted : 26/05/2010 11:48 am
1: There's a leak.
2: Get them serviced.
Next: My hair is getting longer, how can I shorten it? 🙄
Posted : 26/05/2010 11:50 am
I'll try to be a bit more civil.
Do you have more air in the neg than the pos chamber? I believe this can cause them to sit further down in their travel.
My new Rev is doing it too so I need to investigate this as well.
Posted : 26/05/2010 11:52 am
It quite possible there's an air leak from +ve to -ve air, which will drag them down. Service is the only cure for that
But
Try letting all your -ve air out, checking the +ve pressure, then resetting the -ve to no more than the same pressure as the +ve
That will give you your travel beck, but if they keep dropping, it's service time I'm afraid! 🙂
EDIT
Air Pikes seem very prone to this, I've heard of it on quite a few sets, mine included
Posted : 26/05/2010 11:53 am
Tempory fix - drop all the air out of the -ve chamber - they'll extend back to full travel, then refinflate. (worth topping up the +ve air as well as it's leaking out of there into the -ve chamber.
chakaping - Member
It's a dirty job, but someone's got to do it...
Posted : 26/05/2010 12:15 pm
Good advice (barring Woppit obviously, and your wacky sense of humour) dropping then resorting -ve seems to have done the trick. This [b]is[/b] a useful forum!
Posted : 26/05/2010 12:55 pm
