456 BB width for sh...
[Closed] 456 BB width for shimano square taper crank?
3 Users
Got a set of M442 cranks like these - http://www.ukbikestore.co.uk/product/56/shimano_fcm442/shimano-m442-square-taper-chainset-443222.html
I cant find the recommended axle width to get the 50mm chainline that On-One recommend.
Would a 118mm axle give me a decent chainline and avoid any potential chainsuck issues (ie chainrings been too close to the chain stay)?
Ta
Posted : 01/07/2009 8:51 am
And i thought every other STW user had an On-One.... 😉
Anyone?
Posted : 01/07/2009 11:05 am
 Nick
According to this you need 113mm
[url= http://www.sheldonbrown.com/bbsize.html ]Sheldon Brown's BB Size database[/url]
Assuming the 442 is the same as the 440
Posted : 01/07/2009 11:07 am
Lots of on ones out here but probably not many people with that crankset, I had a quick google but couldn't find the recommended BB for those cranks.
You just want a 5mm longer BB than whatever Shimano recommend for a (normal, older standard) 47.5mm chainline, but I guess you knew that.
Posted : 01/07/2009 11:12 am
Cheers Nick, useful link.
Would there be any harm in running a 118mm axle, would it bring the chainline out too much? Probably been over cautious, but as there are a few reports of chainsuck with the newer On-One frames, im trying work out the best way to prevent it.
Posted : 01/07/2009 11:14 am
Thanks Restlessnative.
So reading that a UN26 113mm will give a 50mm chainline. Based on that, any BB with UN, ie a UN54 should also be the same dimension?
Posted : 01/07/2009 11:29 am
Thats how I read it yeah*
Even with a 50mm chainline I found the outer chainring on my 853 Inbred very very close to the stays, so I indented it to give more clearance (like the older inbreds were)**
Since then however I have gone 22/36 with a short cage mech , don't think I'd have gotten that in without the indenting actually
*usual disclaimers apply 🙂
**even more disclaimers apply! but Brant said it was fine
Posted : 01/07/2009 12:21 pm
Posted : 01/07/2009 1:24 pm
