29er Geometry Quest...
[Closed] 29er Geometry Question
I have an opportunity to buy a second-hand 2008 Reba Race (100mm) which has an Axle - Crown measurement of 510mm. The current rigid fork A-C is 490mm. Will the Sag on the Reba even up the difference? The Frame manufacturer specifies corrected for 80-100mm
Posted : 24/02/2011 9:19 pm
have a look on the cotic site under geek,, it shows geometry change with fork length,, 26inch bikes
your sag should be 25 to 30 % of the travel so that brings you back to 485 ish i cant see a problem,,
just check what fork offset your frame is designed for
Posted : 24/02/2011 9:29 pm
Will be absolutely fine.
Posted : 24/02/2011 9:31 pm
