248mm SP spokes? Co...
[Closed] 248mm SP spokes? Correct calculation?
I'm thinking of getting my Hope Pro3 AM4 hubs built onto some LB 33 or 38mm carbon rims. The ERD of my current Flow's is 536mm, the LB's are 515mm (33mm) and 510mm (38mm).
My LBS wheelbuilder has worked out hat I need 248mm spokes for 33mm wide (old ones are 266mm).
I make it 256mm by subtracting the differnece between the ERD's but I know faff-all about wheel building ๐Ÿ˜ณ
Does 248mm sound right and, if so, any ideas where I can get some?
Posted : 20/05/2015 10:40 am
Did you use a calculator?
https://leonard.io/edd/
Posted : 20/05/2015 11:28 am
 IA
You don't just difference the ERD, the spokes don't go radially from the hub.
Also, I'd be waiting till I had rims in hand to measure the ERD accurately till I ordered...
(and then use one of the many spoke calculators out there, remembering to account for nipple length)
Posted : 20/05/2015 11:39 am
My hub isn't on there?
Posted : 20/05/2015 11:49 am
This is the calculator I use: http://www.wheelpro.co.uk/spokecalc/
There's instructions on there for measuring as well, which is always better than relying on someone else's numbers. Output from that gives you lengths for different crossings and also "perfect" and "OK" lengths, depending on what's available.
Posted : 20/05/2015 12:28 pm
I use [url= http://sheldonbrown.com/rinard/spocalc.htm ]the Spocalc spreadsheet[/url] it's getting on a bit now, but has the distinct advantage that you can add data for any hub or rim, I normally scour the web or measure parts and then I can work out spoke lengths...
Plus you can save it/use it offline, it's very handy IMO...
Posted : 20/05/2015 12:59 pm
