2.25 Ardents are ma...
[Closed] 2.25 Ardents are massive!!
9 Users
Got one of these to put on the rear of my hardtail with 2.35 minions up front and its well bigger than the minion. Had a quick blast today and it feels good but to me it just looks a bit odd having a bigger rear tyre than front. Is this just a silly mtb fashion faux pas thing and will/should I just get used to it. Don't wanna swap them round cos I want the grippier minion on the front
Posted : 06/10/2010 6:38 pm
Have you actually measured it? 2.35 Minions measure up under 2.2. Man I hate that. Good tyres though.
Posted : 06/10/2010 6:43 pm
 br
What width on what rim at what pressure?
Posted : 06/10/2010 6:51 pm
it sort of makes sense to have a bigger rear tyre on a hardtail, sort of...
a bigger tyre will allow lower pressures, which can give you a bit more comfort/grip.
Posted : 06/10/2010 6:53 pm
Yup new skool maxxis are way bigger than their older relatives
Posted : 06/10/2010 6:57 pm
Its a 2.25 ardent on a bontager big earl rim, dunno what pressure, wee bit higher than the minion. @ ahiles; was thinking that myself, just looks a bit odd
Posted : 06/10/2010 7:02 pm
I wouldn't worry about it being odd. I like the Ardent as a front tyre too, if you want to balance things up 🙂
Posted : 06/10/2010 7:12 pm
how thin is 2.1 high roller, 1.8 more like!!
and the 2.25 ardents and advantages are mahassive!! cant quite work out who does the measuring at maxxis
Posted : 06/10/2010 7:18 pm
thanks for input people, probably just give it a while to get used to.
Posted : 06/10/2010 7:55 pm
Thinking about ardent or minions for my patriot. Anyone any opinions on which combo will work best?
Posted : 06/10/2010 8:02 pm
currently running 2.35 big earl wet tlr's (front) and 2.25 ardent lust (rear) on my five on flows
great at the trail centres - the ardents roll quite fast on the rear - though can't see either being that great in winter mud
Posted : 06/10/2010 9:06 pm
how do the big earls compare in size to the ardents chunkypaul?
Posted : 06/10/2010 10:44 pm
cause i'm quite sad, i've just checked 🙂 they are both large volume tyres and look pretty similar volume wise
big earls come up 60mm wide
ardents are 58mm
HTH
Posted : 06/10/2010 10:57 pm
So the huge ardents are actually pretty much spot on then?
Posted : 06/10/2010 11:00 pm
thanks man, v. nice of you
