20mm rigid fork
[Closed] 20mm rigid fork
7 Users
I asked this over a year ago at the time the option was an expensive hand made fork or a heavy dirt jumping fork.
Has anything been released since as I don't follow bike press much, I would be fitting it to a Cotic Simple.
Thanks
Posted : 11/01/2012 2:14 pm
Thanks Simon it looks the ticket, it says 29er but I'll look at a to c lengths!
Posted : 11/01/2012 2:24 pm
I think the Salsa is about 470mm.
[url= http://www.dmrbikes.com/?Section=products&pageType=item&category=6&CategoryName=Forks&itemid=FRK20 ]DMR Trailblade[/url] is 440mm
Posted : 11/01/2012 2:28 pm
I think the DMR is a jump bike fork??
Posted : 11/01/2012 2:49 pm
well, you could view it as a very strong trail fork...
Choices are a bit limited really, X-Lite and On One are rumoured to be bringing out bolt-thru rigid forks.
Problem is, bolt-thru is really good for stiffening up sloppy suspension forks. In theory, a rigid fork shouldn't move so much, so doesn't need to be bolt-thru.
Posted : 11/01/2012 3:27 pm
How about a nutted 9mm axle hub? I have a buddy who uses one in the standard Cromoto.
Posted : 12/01/2012 9:16 am
 sv
Or a 9mm QR?
Posted : 12/01/2012 9:42 am
The salsa fork might be quite nice on a simple. Id guess that 470 mm is the about the same as sag adjusted 120-130 mm suspension fork so spot on.
I think the DMR at 440 mm is like a 100 mm suspension fork with sag.
Not sure if the rake would be different on the salsa being a 29’r fork, (would this matter to much?) but might be worth dropping an email to Cotic (or Sasla) to ask
Posted : 12/01/2012 10:09 am
And for stopping your wheel loosening under braking, which can apparently happen with QRs/discs.
X-lite 15mm carbon fork appears to be vapourware.
Andy
Posted : 12/01/2012 10:45 am
Bolt through provides a huge increase in torsional stiffness which is the main benefit, nothing to do in the majority of cases with suspension, that would only really be an issue if the lowers were separate on each leg rather than bridged
Main benefit is felt in steering / tracking precision IME
Posted : 12/01/2012 4:42 pm
