2012 Epic Seatstay ...
[Closed] 2012 Epic Seatstay removal-How?
4 Users
Ok so what the trick for getting the seatstay off so i can replace the bearings?The shock mount is narrower than the seat tube so how do you get it off. For the record ive done a good number of fsr bearing replacements so not after bearing removal tips thanks-just how to get the stay off-if you can...
Posted : 14/11/2014 3:51 pm
If you google Specialized Epic 2012 technical manual there are exploded diagrams on page 18 of the pdf.
Tried to post a link but failed. Hth
Posted : 14/11/2014 4:21 pm
There is indeed a diagram but that's just a schematic of the frame-the question was how do you get the seat stay off -or am I missing something?
Posted : 14/11/2014 9:08 pm
[url= http://forums.mtbr.com/specialized/2012-epic-chain-stay-removal-826841.html ]Does this explain it? [/url]
Posted : 14/11/2014 10:14 pm
No-have you actually done this or are you just trying to be helpful?
Posted : 14/11/2014 10:20 pm
I have actually done it, the seatstay bridge is flexible enough you just push the dropout together just enough to get the ends to pass the seat tube, yes a little scary at first but it's fine.
Posted : 14/11/2014 10:28 pm
Just trying, unsuccessfully, to be helpful.
Edit. Kept it on the first page though
Yep just give it a gentle squeeze , it won't take much force.
Posted : 15/11/2014 8:05 am
