10sp chain recommen...
[Closed] 10sp chain recommendations please
I'm currently accumulating parts for my new build 1x10
Any recommendations for a strong, light 10 speed chain please?
Posted : 31/03/2013 10:40 pm
quite impressed with my clatks self lubricating ones, can be found cheap on ebay too
also here,
http://www.amazon.co.uk/Clarks-CSL-H10CR-lubricating-speed-Derailleur/dp/B006VCX5N0
reuseable joinig link too
Posted : 31/03/2013 10:41 pm
XTR hollow pin.
KMC SL
Posted : 31/03/2013 10:54 pm
 tang
wipperman connex, had it on 1x10 very strong and long lasting!
Posted : 31/03/2013 11:07 pm
 mboy
KMC for durability, but not the SL version. Just go for the normal X10.93. In a 1x10 setup you'll stretch the chain a lot more than you would in a normal 3x10 setup, so for the sake of an extra 20 grammes it's better to go for the heavier (and cheaper) version IMO.
Posted : 31/03/2013 11:09 pm
I use the KMC ones from on-one for £15. A lot less than the Shimano ones and i've found it a lot more reliable!
Although I think the reason for constantly breaking the shimano ones was joining them without the poncy proper 10spd pins - but i'm really not sure why they bothered reinventing the wheel there when a powerlink works fine with everything else.
Posted : 31/03/2013 11:14 pm
KMC X10 L - just ordered one from here:
http://www.vanillabikes.com/cart
Posted : 31/03/2013 11:34 pm
KMC ordered, ta!
Posted : 31/03/2013 11:49 pm
Another KMC X9-93. Wouldn't use anything else tbh.
Posted : 01/04/2013 12:28 am
KMC X10.93!!! had the shimano chain that came with my bike snapped after a few rides, got this bad boy and looked over alot of reviews..... wouldn't bother with the SL version as you want a strong chain... having holes in it doesn't make it strong!
here is where i got mine if it helps nice and cheap!
http://www.ebay.co.uk/itm/370711227199?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Posted : 01/04/2013 12:56 am
+1 KMC. Not used anything else for the last five years.
Posted : 01/04/2013 9:01 am
I had the SL version in 9-speed, it seemed perfectly strong in terms of pedalling etc but it was as weak as piss if it got twisted- ie, it chainsucked.
Posted : 01/04/2013 1:39 pm
I disagree, I've found chains last longer on a single ring set up - better chainline and that. To that end I use X10SLs, wouldn't bother on anything but a lightweight build though.
Posted : 01/04/2013 1:49 pm
Weirdly I've gone back to Shimano, using a 105 spec 10 speed.
Posted : 01/04/2013 3:26 pm
wippermann connex black edition £45 but last three times as long as a normal chain (not tested and could be marketing bull but still a black chain with gold links looks fly as)
Posted : 01/04/2013 4:20 pm
