09 Enduro- what all...
[Closed] 09 Enduro- what allen key for lower main pivot?
 hora
Totally stripped the frame however I cant undo the bottom main pivot. Off to halfords but what size allen key do I need? Its huge.
Posted : 13/05/2012 7:08 pm
heard of a ruler?
Posted : 13/05/2012 7:11 pm
Your joking right?
Posted : 13/05/2012 7:12 pm
hora - Member
selling it by chance?
Are you a burglar?
Cant remember
It's huge
I definitely have one that fits. Somewhere.
Posted : 13/05/2012 7:14 pm
Same size as proper Old school crank bolts
Posted : 13/05/2012 7:19 pm
 hora
If only I had a ruler. Im not a school student or Engineer 🙂
Stripped for the front triangle to be powdercoated Ral1021 Yellow. Rear black.
Posted : 13/05/2012 7:22 pm
It'll be a 6mm or 8mm from memory, 12 or 13 nut on the other side
Posted : 13/05/2012 7:23 pm
 hora
I'm guessing its 8mm then, ta 🙂
Bregante, I hope you weren't waiting outside Halfords all night in a sting operation 8)
Posted : 14/05/2012 7:44 am
 br
You haven't a set of allen keys - and you've been MTBing for how long?
Oh, I forget, you never normally keep a bike long enough to actually need any tools... 🙄
Posted : 14/05/2012 8:05 am
 hora
You'd carry round allen keys [i]THAT [/i]big?
Posted : 14/05/2012 8:06 am
Who doesn't have an 8mm allen key?
Posted : 14/05/2012 8:59 am
 hora
On a portable Parktool 5mms the biggest?
Posted : 14/05/2012 9:03 am
Are you removing this front triangle from a bike in the street?
The owner will not be happy when he/she comes back to find it missing.
Surely you have more than a park multi tool for your bike maintenance.
Posted : 14/05/2012 9:12 am
 hora
No, never needed those fancy sets. My tools consist of a cutter, pliers, claw hammer, rubber hammer, threaded dowling rod (for headset fit), overly-large adjustable spanner and a couple of other bits and bobs. Nothing professional or even an apron..
Posted : 14/05/2012 9:21 am
I think you forgot to mention the bolt croppers. Definitely.
Posted : 14/05/2012 9:26 am
I'm cringing at the use of an adjustable spanner.
Posted : 14/05/2012 9:52 am
 hora
Great for fitting headsets, great for rounding the edges of things 😉
Posted : 14/05/2012 9:53 am
Hora,
Do your self a favour when you go in to halfords, pick one of [url= http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_173083_langId_-1_categoryId_255215#tab1 ]THESE[/url] up rather than just a 8mm Allen Key. It will give you tools not only to strip the bike but sockets to replace bearings and service your forks.
Posted : 14/05/2012 10:04 am
If you bought the small sized one yes, otherwise no.
Posted : 14/05/2012 10:28 am
I think you are best off trying to undo the nut on the non-drive side with a spanner while holding the other side with an allen key.
 hora
Rusty. Its probably a good idea. £100 is a lot but if it lasts.
Posted : 14/05/2012 10:30 am
It comes with a lifetime guarantee on the non moveable parts so if you break a spanner or socket then you just take it into the shop with the receipt and they give you a new one.
I know of someone using a socket to remove a broken locking wheel nut – they smacked the socket onto the wheel nut with a lump hammer and then removed the nut. Took the socket back to Halfords and no questions asked got a replacement.
Posted : 14/05/2012 10:42 am
You do not need that set. The only sockets you need are a 24mm shallow drive and, if you have dual air forks, a 10mm deep drive.
And a pair of circlip pliers.
Posted : 14/05/2012 10:48 am
