XX1 / X01 Cassette ...
[Closed] XX1 / X01 Cassette Wear
Weight isn't everything though and rather than just steel it features some Ti too.
Ti is softer than steel, so it'll wear quicker than XX1, as a greater proportion of the cassette is ti. The only longevity benefit is that there's no alu 42, but there's no 42 at all, and longevity of the 42 isn't really an issue anyway.
Am I right in thinking the XTR will fit on a normal freehub body too? That saves even more money.
That is true, so it depends on whether you're building from scratch or not.
Glad Shimanos in the game (with a cheaper price and retro fit option too).
I agree that competition in this respect is only good, but it is only £50 cheaper than XX1 as a whole groupset, and more expensive than X1, it's not really a low cost option per se.
Don't get me wrong, I much prefer Shimano stuff, but IMO M9000 isn't a true rival to XX1, it's a more holistic groupset solution, with the double and triple options. I've long said I don't think Shimano are trying to take the market segment from SRAM and XX1. There are a lot of misconceptions around the cost of XX1 which are largely wrong.
Posted : 23/09/2014 4:14 pm
just another update - ive just calculated using garmin connect my mileage since I had it
now about 1472 miles! its still actually shifting fine (bar sometimes it takes a little longer in 3&4th to shift but nothing too long and absolutely like new still shifting up through the same gears), and to be fair its probs more so to do with cable stretch (new cable etc)
so on that basis, given that's all peak mileage (bit of wales/lakes/etc etc) all thrown in its actually quite good I think, ok yes weve had a great summer so its endured a easyish weather wise usage but still good going, theres ALOT of climbing involved in those miles too which id imagine adds to wear,
I must admit im shocked its still going really strong, and even the alloy cog albeit looking a lot worse than the rest has only slipped on me one ride (due to lack of lube if nothing else!)
Posted : 01/10/2014 3:37 pm
Can someone take a look at this, I have been in touch with SRAM Tech and explained that I am having problems with noise and shifting after 3.5 months with a new XO1 drivetrain and they said it might be a warranty issue and to take it to a bike shop. I know chainrings get hooked when worn but would appreciate a second opinion on these before I follow it up.
I have found that the chain is a little worn being somewhere between 1/8" and a 1/16" stretched over 12". I have calculated I have done about 300 miles through the summer since new in June.
Expensive if I have to replace 3 times a year at £85 a time and this was the driest summer for years.
Posted : 01/10/2014 10:36 pm
looks like my chainring did after 100 miles, whats your issue? is it dropping the chain?
Posted : 01/10/2014 10:46 pm
i essentially rode my launch month XX1 drivetrain, with little maintenance, for over a year, my chainring and jockey wheels looked like this, the cassette was worn as much, and the chain, never, ever dropped once
Posted : 01/10/2014 10:54 pm
It makes a noise under force that sounds like it is skipping at the front I have stripped everything down lubed crank cassette splines etc. but cant get rid of the noise and it seems to be getting worse. Shifting is not great but I guess that is the chain my main concern is if the noise is because the chainring is worn.
Posted : 01/10/2014 10:55 pm
sheeesh mine looks new 🙂 think I should just change the chain and try that?
Posted : 01/10/2014 10:57 pm
when you fitted the chain did you shorten it as per the sram instructions? Could be chain is too long.
Posted : 01/10/2014 11:07 pm
Yes I did 2 chain links visibly it looks right too when in highest and lowest.
Posted : 01/10/2014 11:23 pm
m_t_b - not sure what you think is wrong? the chainring looks absolutely fine to me???
if its purely just the noise, then are you riding gritty/wet etc? cos it does make a hell of a lot of noise if im honest until the lube clears it all off, in summer dryness mines is absolutely silent, but on wet and muddy/gritty rides it does sound awful, sadly that's just the nature of the thick/thin ring up front i'd guess
if its not dropping the chain and shifting fine and just the noise issue then that's just how it is, just make sure you lube up plenty and try and keep the whole system clean and debris free! (especially oily gunk on chainring and jockey wheels)
Posted : 02/10/2014 8:56 am
Yes I can see where you are coming from looking at above just not sure whats making the noise, its in the dry and the wet, I use a fairly dry lube so its not clogging up. It started about 2 weeks ago and has been getting worse so I'm thinking it could be the chain thanks for taking a look,I always find it hard to gauge wear on chainrings.
On a side note any idea if KMC chains are worth a look?
Posted : 02/10/2014 9:56 am
Two links visible? That's not what sram says. You take the chain off rear each, compress suspension and then shorten on biggest rings
Posted : 02/10/2014 9:58 am
Mine was noisy after I changed the chain, a sort of grating when pushing hard, particularly in the larger sprockets. Seems to have settled down, particularly after a good clean and lube with Squirt, although probably coincidental.
Posted : 02/10/2014 10:01 am
Mine also made a grating sound when pushing hard, but it was a knackered chainring - replaced & it went away 🙂
Posted : 02/10/2014 10:35 am
Same experience as njee20 on new chain. Now running quiet. Also best thing I did was to drop down from 34 to 32 chain ring. Lot better wear in the mid range at the back and also better chain line which also helps to reduce wear overal.
Posted : 02/10/2014 10:54 am
it does love being 'lubed' up, I find nearer the end of a gritty peak ride it sounds far worse than at the start, keeping it all clean is the real key to both performance and longevity/noise I've found
as I said last week in the wet and mud, it was noisy, out the other night in the dry and it was silent throughout
the noise will be coming from the chainring/chain interface on the thicker front teeth, theres no room for grit/mud to pass and the noise will be a lot worse than a normal chainring
that's my take on it as it stands, again once it all starts to clear (road section or dry section after the grit/mud) it does eventually clear itself
also as its so important the b-screw actually makes a hell of a lot more difference to noise/running smooth etc than any other gearing ive used, if its just a quarter turn to far either way it can affect its shifting/noise too
still worth it all though 😉 and still no dropped chain for me yet 1500 miles in
Posted : 02/10/2014 11:29 am
Well, I've just changed the chain on my X01 at the 0.5 chain stretch after 600 miles and the 42t cog jumps like crazy on the steep climbs, put the old chain back on and it appears fine. So should I just run the old chain and chain ring / cassette into the ground or should I try replacing the 42t cog? Found an Italian website which appears to offer a replacement, but can't find any other info on whether it works or not. Although at 90 euros its a lot cheaper than buying a whole new cassette, but is it worth the gamble?
http://www.aribike.it/pignone%20sram%20XX1%20html/pignone_cassetta_sramXX1.htm
Posted : 07/10/2014 11:52 pm
Just keep running the old chain and cassette and then replace the lot when it stops working.
Although you may have ruined the new chain by now.
Posted : 08/10/2014 12:00 am
Then consider a smaller chainring so you're not using the 42 as much.
Posted : 08/10/2014 7:23 am
The 42T seems quite sensitive to setup being correct.. mine was starting to jump so I thought a new cassette was imminent. Turned out the mech hanger had come loose (mech itself seems to occasionally too) resulting in unwanted side-to-side movement - tightened everything up and it seems fine now. Cheap fix! 🙂
Posted : 08/10/2014 8:08 am
Yeah those were my thoughts as well, guess when I've worn it out and I replace it I could run two chains and alternate them. Might try one of those oval chain rings as well next time around to help me pedal more consistently up the climbs. Did manage one climb in 2nd gear on Sunday so maybe I should just MTFU and pedal harder!
Tom
Posted : 08/10/2014 8:12 am
Or fit a smaller chainring...? 😕
Posted : 08/10/2014 8:24 am
rooster - out of interest did you cut the new chain to exactly the same length as the one it replaced?
I found/remember when I changed my chain last time, I added 2 links to the new chain as I thought it was maybe a tad too short, and it did exactly the same in 42t cog, I took the 2 extra links back out and it shifted back to normal, it was jus in that 42t cog the same as you describe
mines is starting to get a little slow now shifting in some gears I must admit, much better when freshly cleaned/lubed, but aftr a few hours in the saddle shifting down to 3/4th and now 11th is becoming a little laborious, im just hoping to run it out through winter now and change it all in the new year, as thers no point in changing one item now going into winter, I may as well just run it in the ground!
and as njee says, get a smaller ring up front if your using it all that much, then youll be able to use the 2nd cog down (which is steel) for a lot of the climbing, and only use the 42t when desperate/legs gone etc
Posted : 08/10/2014 8:47 am
I cut the chain to the same length as the one it replaced, worked ok in all the gears apart from 1st (42t) but only on steep climbs, but noisy in all the gears. I could put an easier cog on the front and not use the 42t as much, but doesn't that defeat the point of having the 42t? Or are you suggesting that less load on the 42t by having a smaller front chain ring will reduce wear? For info I'm running a 34t on the front with 26 'ain't dead' wheels, the whole bike with transmission was new from May, and considering its been the driest Summer in the Lakes for the last 6 years its not had a hard life. Chain de-greased and lubed after every ride, although I have recently swapped from Wet Lube (Green) to R&R Dry Lube (Blue) which is slightly noisier but less mess.
Tom
Posted : 08/10/2014 9:24 am
I haven't noticed much wear on my cassette and checking the chain that seems fine too and have done 670 miles on them. But I do find that it takes an extra second longer to change down the gears. First I tightened the cable and then noticed that the derailleur wasn't tight to the hanger. I tightened this up but there was still a slight wobble as if the bolt on to the hanger was not tight enough. Is this normal to have a little bit of play? Or is there supposed to be a washer between the hanger and derailleur? 11 speed X01 cassette and derailleur btw. Thanks
Posted : 08/10/2014 9:27 am
I've not long changed my xx1 chain for an x01 chain and now it's doing exactly the same as yours.. I wonder if there is something weird about the X01 chains that causes the issue
Posted : 08/10/2014 5:04 pm
I used a XX1 chain, same as the previous chain so I don't so.
Posted : 08/10/2014 5:13 pm
Have e-mailed the Italian website for more info on the replacement 42t cogs, will let you know how I get on.
Posted : 08/10/2014 5:15 pm
Well it all worked perfectly last night around the Lakes with the old chain in torrential rain, mud and grit. My phone didn't fare so well but that's another story (need a waterproof pouch).
Valentina at Ari Bikes has come back and said a replacement cog is 75 euro's plus 30 euro's shipping. Bit expensive but cheaper than a replacement cassette so I'll try one out and see how it goes, I suspect it should be no worse than the One Up range extender I tried earlier this year on a 1x10 setup, which worked really well. So fingers crossed that it fits OK, will report back if people are interested.
Tom
Posted : 09/10/2014 10:33 am
That depends, if you're spending a lot of time in the 42 (and rarely using the other end of the block?) I'd be looking to downsize. I'd sooner have the 42 as a bail out for the absolute steepest of climbs, rather than the gear I rely on to get me up anything uphill as you appear to:
Not all that surprising it's worn if you're doing all your climbing in it!
Posted : 09/10/2014 10:54 am
Well, I'll give a go and try a 32t on the front, but I suspect I'll still end up using the 42t for the climbs. When I ride my 3x9 hardtail I always use the 34t for the climbs on the 22t granny ring, which is easier to pedal 22t/34t = 65% compared to 34t/42t = 81%. Changing to 32t/42t = 76% or maybe go for 30t/42t = 71%?
Posted : 09/10/2014 1:05 pm
Do you ever use the 10t?
If you were always climbing in 22/34 before I'd not have gone single ring myself...
Posted : 09/10/2014 1:08 pm
Only use 10t on the descents and on the road, what sort of terrain and riding are you doing? I'm riding rocky and steep and take my time on the climbs and then pin it on the descents. A lot of the climbs I do are too difficult to ride and you have to carry the bike anyway 🙂
Posted : 09/10/2014 1:29 pm
I'm getting a lot of grinding now when pushing on rides. It happened today, everything started fine then half way into the ride grinding noise that I could feel through the pedals started. My mate jumped on my bike and as I followed him I could see the chain being held on to long at the bottom of the chaining. Like chain suck. But then a few miles more in I noticed the noise had gone and all seemed fine again. Do you guys think this is just grime on the chain or the chain is worn? 700 miles done on this set up.
Posted : 12/10/2014 3:05 pm
Sounds like the chainring is worn, I know mine is! Once I get my 42t cog replaced, I'm going to re-fit my new chain and reverse the chain ring to get some more life out of it, although I find my grinds more when using dry lube compared to wet lube.
Riding around the Lakes this weekend, I've started making a mental note not to use the 42t unless I really need it, I guess I was using it too much without realising!
Posted : 13/10/2014 12:13 am
Yeah you're probably right rooster, can't believe it's worn that much though after 700 miles of dry summer riding 🙁 Also as the problem seems intermittent would you say that was down to a bit of sandy grit getting on the chain while riding? I have been lubing mine with muc off dry lube religiously after and before rides, does dry lube hold the chain that much more than wet lube then?
Posted : 13/10/2014 11:01 am
I was using wet lube this weekend and it was noticeably quieter than when I was running dry lube over the summer. It only grinds when putting the power down, same as yours, but its always been a little noisy from new compared to a Shimano 1x10 XT setup running a Raceface 34t chain ring and One Up 42t cog that I had on my last bike.
Posted : 13/10/2014 1:28 pm
Ok, my 2p worth.
I have been running X01 on my full bouncer for about 10 months now. I changed the chain out at 600 miles and did that again with the second one. So i now have 3 chains in rotation. When i change to a new chain there is considerable suck as the front chainring seems to not not want to let it go but that only lasts for 1 ride then its smooth operating as usual.
My 11 speed does not like muck, the tolerances are too tight with the NW chainring and the jockey wheels. Thats the only time i have issues with my shifting though. Also there is a horrible grinding noise when there is muck involved.
I run a 32 front ring as that gives me a good climbing vs normal running ratios. I very rarely use my 42 cog as i treat it as a get out of jail gear.
I am a bit anal about keeping it clean though. When you pay so much for that type of kit then 10 minutes after every ride is well spent cleaningthe drivetrain. So far it seems to be working for me. No abnormal wear and tear. And i have never dropped a chain yet 🙂
Posted : 13/10/2014 2:17 pm
Good advice Mactheknife, going forward I think I will change to a 32t up front and use the 42t cog less. Although I haven't had any problems with it apart from changing the chain after 600 miles and realising that I'd worn out the 42t cog, it still runs like new with the old chain on.
Through mud and grit it never seems to let me down, this weekend I was quite impressed with the strength of the rear mech, as I was bouncing down Gas Gale Gill in the Lakes, I hit a rock and the rear mech went into the rear wheel locking it up instantly. I managed to extract the rear mech that was jammed into a spoke by rotating the wheel the opposite way and after a little fettling and adjustment it is still shifting well. I think a lesser mech wouldn't have survived so well!
Posted : 13/10/2014 3:07 pm
Shiny!
Remove the worn out cog
Ta da!
Seems to work OK, will find out tomorrow night 🙂
Posted : 22/10/2014 12:30 am
Interesting! Good job.
Posted : 22/10/2014 7:33 am
Where's that from?
Posted : 22/10/2014 8:38 am
interesting that, strangely my 42t cog is still shifting like new (even under load) some 1800 miles on, it only slipped once when I hadn't lubed the chain for a ride and went through mud/wet
but my 3rd and 4th cogs are becoming a real pain to shift into now, and 11th cog, not sure if that's related to having a new cable in or not, or whether the cassette is just getting goosed now
Posted : 22/10/2014 8:43 am
dirtyrider - Member
Where's that from?
Ari Bikes
[url= http://www.aribike.it/pignone%20sram%20XX1%20html/pignone_cassetta_sramXX1.htm ]http://www.aribike.it/pignone%20sram%20XX1%20html/pignone_cassetta_sramXX1.htm[/url]
Posted : 22/10/2014 8:54 am
90 euros? hmmmmm if i got to the point where the 42 was worn id bin the whole cassette i think and buy fresh
Posted : 22/10/2014 9:05 am
Page 3 / 5
