Whats that money sa...
[Closed] Whats that money saving thing...
[#3451367]
...Where you get money back from purchases?
Posted : 12/12/2011 1:53 am
quidco or one of the other similar things? zillions of threads on this, most likely. use that name as a starting point.
Posted : 12/12/2011 2:19 am
I use Topcashback.com, they're very good and pay quickly.
Posted : 12/12/2011 6:58 am
Green Shield stamps?
Posted : 12/12/2011 7:39 am
not certain , but i will search the tips online ! 🙂
Posted : 12/12/2011 7:44 am
Ta, will have a look.
Posted : 12/12/2011 11:35 am
 cp
I use topcashback - only recently started using it, but very simple & purchases all seem to have tracked OK.
Posted : 12/12/2011 11:37 am
+1 for Topcashback, everything's tracked & paid out for me over the last couple of years.
Quidco seems to have become very erratic with tracking stuff.
Posted : 12/12/2011 11:43 am
Well, signed up at Topcashback to find that every link I follow results in full RRP. load of crap in my opinion - got nearly everything from Amazon at significantly less than any of the retailers via topcash...
However, even more annoying is the thrice daily emails trying to sell my shite.
Posted : 19/12/2011 1:33 am
Amazon aren't on topcashback... But CRC and Wiggle are. So are the trainline, AA, RAC...
Posted : 19/12/2011 3:09 am
Yes, that's my point - Amazon aren't on there and the products cost significantly less than the retailers who are on topcashback, meaning the savings outweigh the money you get back.
I didn't know CRC were though - Ive spent a small fortune with them recently.
Posted : 19/12/2011 11:32 am
Aye, the way to use it is generally just to shop normally, but use it when you can, rather than letting it influence how you shop too much.
Posted : 19/12/2011 1:41 pm
As Northwind says, find the place you want to buy from THEN check QuidCo/TCB to see if they can get you any discounts.
Posted : 19/12/2011 1:44 pm
You get Nectar point at Amazon, may as well get everything you can from them, if you are going to buy from there.
Posted : 19/12/2011 1:47 pm
alternatively if you are using Amazon you could go through http://www.goodsearch.com/goodshop.aspx to get there. Then a percentage of your purchase goes to a charity. I haven't used them personally but our org. used to use a similar Danish thing called EnGodsag that worked in the same way. Never got a huge amount but it all helps.
Posted : 19/12/2011 2:23 pm
