VHS to DVD
[Closed] VHS to DVD
 Muke
[#1370414]
Was about to throw out our old VHS player but found a couple of tapes of family stuff that needs to be kept. So whats the best way of transfering to DVD ?
I've seen the gadgets that plug in between your PC and video player but they seem to vary from £5 to £40 so is there any particular make that is best ?
Thank you
Posted : 01/03/2010 8:43 am
Can't you just connect the VCR A/V out to the DVD recorders A/V in?
a simple phone/Scart lead should do the trick
Posted : 01/03/2010 9:07 am
[url= http://www.maplin.co.uk/Module.aspx?ModuleNo=96885#features ]Dazzle DVD Capture[/url]
You will also probably need a Scart to Red/White/Yellow lead - about another tenner.
For the best results, use the fastest PC you have to capture the video or it may be a little jerky.
Posted : 01/03/2010 9:09 am
The Dazzle hardware is ok but the software (last time I tried it) was rubbish. I have found a free bit of software that will take the input from the Dazzle and save it as any type of video format you want, but I can't remember what it was called and I'm at work now.
Posted : 01/03/2010 9:19 am
Unless you want to play around with the output [e.g. compile a DVD] & are happy to simply transfer the contents of each tape to a DVD
You don't need anything other than a couple of A/V leads [less than a fiver]
Posted : 01/03/2010 9:41 am
