Using different wei...
[Closed] Using different weight oil in Fox forks
 st
[#3784592]
I'm about to put some fox Van 36s back together after a strip and clean but don't have any 10 weight oil for the lowers.
Will using 15 weight oil affect their performance or the lubing of the bushes? I do have some 5 weight so could mix a bit of this in to thin the 15 weight out a bit.
Ta.
Posted : 18/03/2012 3:20 pm
When I serviced my Van 36 FIT Kashimas I used 5wt as thats all I had, that's was 6 months ago and seems ok so far!
It's only to lubricate the bushings so should be fine, next time I get some I will get the 10 wt.
The Fox site is very inconsistent with oils, MOJO uk say uses float fluid for the foam rings because of our weather in the uk, but FOX something different
As long as they are cleaned, lubed regular then can't see any problem!
Posted : 18/03/2012 3:26 pm
Float fluid is way heavier than 15wt so if you can use that OK, then 15 wt will be fine. I've been putting all sorts of different oil in various Rockshox forks, it makes no perceptible difference, although I don't have any experience with Fox.
Posted : 18/03/2012 3:35 pm
it'll be fine, it will probably slow the rebound and compression speed a bit.
Posted : 18/03/2012 4:19 pm
hes was talking about the lowers....these have no affect on damping/rebound/compression characteristics
Posted : 18/03/2012 4:51 pm
he doesn't say whether they are FIT or open bath.
Posted : 18/03/2012 4:53 pm
he did mention lubricating the bushes
Posted : 18/03/2012 5:13 pm
Sorry for the hijack, but since we're talking about fox servicing my forks are currently in pieces on my kitchen table. I've removed the lowers but for the life of me can't get the seals out 🙁
I've looked at the how to guides, but mine seem stuck fast. Any suggestions/tips. I reckon brute force would get em out, but don't want to mangle the inside of the leg.
ta
Posted : 18/03/2012 5:16 pm
The damper cartridge on FIT or non-FIT fox doesn't have any impact on the semi-bath either way.
Posted : 18/03/2012 5:52 pm
 st
Thanks all, figured it would be ok, I've done the same before on Rockshox just never service Fox before.
Posted : 18/03/2012 8:27 pm
