tough 700c wheels
[Closed] tough 700c wheels
[#1537029]
Spokes keep snapping on my road bike! I suspect the weekly trips to sainsburys are taking their toll on the wheels.
Can anyone reccomend a strong 700c wheel?
Currently thinking of planet-x model c or finally getting a wheel truing stand and building one myself properly.
i've no local bike shops really, nearest is 10 miles away and a pain to get to.
Posted : 23/04/2010 9:49 am
campag scirroco
seem to be bullet proof and Ribble are seling them for a silly low price
Posted : 23/04/2010 9:57 am
a touring wheel? then swap in your light weight wheel when you want to train / ride unloaded
Posted : 23/04/2010 10:58 am
speak to spa cycles at harrogate they will sort you out
Posted : 23/04/2010 11:10 am
I've got a nice set of Mavic Open Pro Ceramics on Hope MTB hubs hand built by my local wheel crafting emporium.
I'm a luddite, I can't entertain these pre built wheels, even spangly high end efforts........
Posted : 23/04/2010 11:19 am
went for a 36 spoked mavic open pro on tiagra hub in the end from parkers
can't be bothered with wheel swappage etc.. Problem with a touring wheel is they seem to be designed for bigger tyres and i've got some close clearance full length mudguards on.
Posted : 23/04/2010 11:31 am
Touring wheel with a Mavic rim. I run a Mavic A3?? on a shimano dynamo hub on my do anything bike with a 700x25 Vittoria Rubino and mudguards, works OK clearance wise.
If you're snapping spokes regularly then consider a new wheelbuilder, they shouldn't break that often!
Posted : 23/04/2010 11:39 am
ive open pro on my cx and have banged it all over and its been fine also have them on the road bike. great rims .
Posted : 23/04/2010 11:42 am
American Classic Hurricanes or failing that Ambrosio Nemesis rims onto a hub of your choice
Posted : 23/04/2010 11:53 am
I got a couple of touring wheels for my tricross built by the aforementioned spa cycles and they are spot on - shimano hubs of some sort with sputnik rims.
Posted : 23/04/2010 11:56 am
Handbuilt without a doubt. Ambrosio Excellence rims on whatever hub meets your budget.
Ambrosio are always stronger pound-for-pound vs Mavic.
I have a set of Excellights (the lighter version) on my winter bike, a set of Nemesis (super strong, the benchmark rim, but tubular only) on my CX bike and have run Excellence in the past. Great rims. Not as flashy loking as a set of factory builts, but generally lighter, stronger and more easily repaired.
No matter how I equip the rest of my bikes, I always use handbuilt wheels. They are completely bespoke, and the sum of the parts is usually better than the factory built alternative.
Posted : 23/04/2010 12:06 pm
My Ultegra wheels are taking a serious pounding at the moment, my 15st and horrendous roads around me and they haven't budged. A few times I've thought ooouuuuccchhh that's a new wheel pothole I've just hit!
Posted : 23/04/2010 12:50 pm
I use Mavic speedcity wheels on my commute. Pretty bullet proof
Posted : 23/04/2010 2:40 pm
