Ti456 on TALAS 150m...
[Closed] Ti456 on TALAS 150mm
[#3547680]
realistic or not ?
TIA
Posted : 10/01/2012 10:22 am
Why not?
Posted : 10/01/2012 10:24 am
Would be fine IMO, even GREAT 😀
Posted : 10/01/2012 10:25 am
 ojom
If on a 26" surely it will be rubbish regardless. 😉
Posted : 10/01/2012 10:26 am
now now bikechain.
that was a point for discussion 🙂
Posted : 10/01/2012 10:33 am
 ojom
Teasing.
as for the OP, what apprehensions do you have. Sure it would work fine. Just stick em on and forget about it.
Posted : 10/01/2012 10:34 am
TLR I ran a Ti456 with 150mm forks for a little while and it was great.
Posted : 10/01/2012 10:53 am
geetee - full thoughts in your in-depth style please ?
Posted : 10/01/2012 11:02 am
It would be perfect.
Got a 456 with a RS Rev 150 on it. rides fine but have to watch my technique on steep climbs to keep the front under control. A TALAS would be great for it.
Posted : 10/01/2012 11:07 am
Mate would love to but I can't today. I will try and drop you a line later.
Posted : 10/01/2012 11:09 am
I think you need to share with the class
Posted : 11/01/2012 7:41 am
When i first built my 456ti up I didn't have spare foks to suit so i used the 160mm Fox 36's off my Enduro.
It was fine with them if a little OTT.
Preferring mine at 130mm these days with U turn Pikes.
Posted : 11/01/2012 7:48 am
 br
Run 140mm's on mine and don't bother with the talas (or whatever Magura call it), able to out-climb most and to the limit of the granny. Tried with 150mm 36's, just ended up running more sag.
IME If 140's are cheaper than 150's, go for the 140's - and I wouldn't bother with the talas.
Posted : 11/01/2012 9:54 am
Currently has float 140 rlc 15qr on it....
Posted : 11/01/2012 11:12 am
run 160mmlyriks on mine, it's great going down stuff, thankfully they are two step flavour and switch down to 120mm for goingup stuff at the flick of a lever.
Posted : 11/01/2012 7:30 pm
Then I suspect not even you will notice the extra 10mm (although your missus might)
Posted : 11/01/2012 8:11 pm
I'd sooner run my 456 at 140 than 150, seems like a backwards step. Is it the latest TALAS or an older 3-position one?
Posted : 11/01/2012 8:23 pm
latest @ 150.........
Posted : 11/01/2012 8:41 pm
