Turbo – Post now recieved and fitted.
Had a wee bit of a problem at first due to the smallest of parts – the 10mm wide cable clamp that fits the cable to the post – not being in the box when it arrived and spent a week chasing the shop to send it to me.
Anyway, part arrived this morning and just fitted it now.
So, first impressions.
Out of the box it’s a really nice looking bit of kit, understated with clean lines etc. The seat clamping bit is well worked and very easy to adjust with one bolt. The bar mounted lever works well and looks good – personal preference as to whether you have it above the bar on the left or under the bar on the right i suppose.
Surprisingly ‘mechanical’ feeling in operation, you can really feel the solid ‘clunk’ as it finds its position which i like, feels like it is solidly built. The return spring is air-powered, at the moment i have it set to the maximum reccommended setting at 40psi. From fully down the return is pretty fast up to the middle setting but rather slow from there back to the top setting, i reckon this is to do with the seals being new and tight and think it will speed up over time, although it’s nice not to have it hit you in the balls when it raises to full height!
No noticable lateral play at the moment, feels almost like a normal seatpost so damn good in that respect.
I’ll be out on it tomorrow so i’ll give you a better review once i’ve ridden it 🙂
