Smokey Diesels - wh...
[Closed] Smokey Diesels - why is it...?
[#3197086]
Why is it that, whenever I see a smokey exhaust, it seems to be part of a Ford Diesel?? Either a Mondeo or a Focus.
Are they more susceptible to it or something?
Rachel
Posted : 29/09/2011 8:09 pm
Plenty of other smokey diesels on the road. Most of the ones I've noticed lately have been VAGs though.
Posted : 29/09/2011 8:13 pm
Not just Fords ime, seeing almost new cars puff out black smoke at every gear change means I'd never buy a diesel - too dirty.
Posted : 29/09/2011 8:15 pm
Could be a million different things from a leaky gasket to a stuck EGR valve. The main reason is the driver. Mondeo owners are in middle age denial and Focus drivers like to make everyone think they've got an ST. As a result they both have bricks over the gas pedal.
Me, I've got a diesel Vectra which I drive like a massey ferguson.
Posted : 29/09/2011 8:17 pm
The guy who was in a rush to pull out of a side road before I got there resulting in the saving of a couple of seconds on his journey and giving me a nice lung full of whatever crap he was throwing out, would disagree with the Ford thing, he was in a Rover.
Posted : 29/09/2011 8:19 pm
You do realise that the exhaust is on the outside of the car don't you?
Posted : 29/09/2011 8:21 pm
I do.
Posted : 29/09/2011 8:24 pm
Of course, visible emissions are far "dirtier" than invisible ones.
Posted : 29/09/2011 9:38 pm
And I have a Massey Ferguson...
Posted : 29/09/2011 10:02 pm
Most diesels are smokey, which is why it pi553s me off that my 'clean' petrol is way more expensive in tax
Posted : 29/09/2011 10:04 pm
 Taff
Low revs letting carbon build up in the system. Put your foot down and that frees the build up. Mine used to smoke badly when I put my foot up after a week of inner city driving
Posted : 29/09/2011 10:14 pm
My Mondeo smokes terribly - had it since 3k miles & queeried it with garage but apparently nothing wrong - the upside is I can give tailgaters a lung full should they get too close 8)
Posted : 29/09/2011 11:00 pm
Thankfully "boffins" can measure this invisible stuff and tax appropriately.
Posted : 29/09/2011 11:06 pm
Junkyard - Member
Well. It all goes off CO2 doesn't it? Which isn't a good measure of pollution.
That said, anyone who thinks diesels are dirtier than petrol, just because of the almost completely harmless soot, is a fool.
Posted : 29/09/2011 11:07 pm
Mine smokes like a chimney, especially when I put my foot down at 65.... Mph.
However my car has done 159k miles!
Posted : 30/09/2011 1:00 am
I discovered today that mine smokes quite dramatically when I try to pull out of a junction in the wrong gear. :/
+1 for the reliability of diesels though, 164k and counting!
Posted : 30/09/2011 1:19 am
I have a Mondeo and when I bought it it smoked big time. Now it doesn't so much as I make sure I drive it hard every so often. Even on the motorway at 80 your only doing 2000 rpm so doesn't really get the soot out.
We also have a newer VAG diesel. On start up that always chucks out loads of soot, but doesn't kick out as much as the Mondeo in normal driving.
Posted : 30/09/2011 4:00 am
Older Fords both diesel and petrol do smoke a lot but that's grey smoke from oil being burned - I don't know enough about Fords to tell you why it's characteristic but it's either down to worn valve guides or worn piston rings.
Older diesels like the 2007 Passat PD I've just handed back, smoke a lot on acceleration; a brown smoke of unburned hydrocarbons. Any fuel burned at too low a temperature or not fully burned will produce smoke as any stove owner knows. The new Passat I've just collected with the new common-rail diesel doesn't seem to smoke at all, no matter how hard I try.
We used to have a 1986 Land Rover diesel, which had a very primitive fuel delivery system. If somebody was driving up your chuff you could declutch and floor the throttle to rev the balls off the engine and a massive cloud of greasy black smoke used to come out, which usually made people back off smartish. Not that tailgaters bothered us because when Mrs Gti got rear-ended by a Freelander it merely squashed our spare wheel carrier while the Freelander was absolutely flattened.
Posted : 30/09/2011 6:28 am
Remaps... the little plug in boxes that boost diesel power just dump more fuel in when you put your foot down, hence possible smokey cars...
Posted : 30/09/2011 6:58 am
Had VAG cars for the last 6 years now and none have kicked out black smoke, the Pugs did mind.
Posted : 30/09/2011 7:15 am
Slightly off topic - what makes diesels so much more economical?
Posted : 30/09/2011 7:20 am
Diesel has a higher energy density than gasoline - so you need less fuel to get an equivalent amount of 'bang'. The trick though is to get all the energy out of that fuel, which is why it has taken until reasonably recently for diesel engines to fully meet the performance (in terms of drivability, smoothness and power) of gasoline engines.
Posted : 30/09/2011 7:33 am
What's gasoline? Must be a pain going all the way to the US to fill up....
Posted : 30/09/2011 7:37 am
Sorry - it's the term we use for petrol at work....don't know why really - obviously become a bit institutionalised! (trust a bloody engineering company to use a name different to 99% of the country....)
Posted : 30/09/2011 7:40 am
it's less down to the difference in energy density, and much more down to the operating temperature.
the efficiency of any heat engine is determined by the temperature drop over which the heat cycle can be run, in thermodynamic terms. for your internal combustion engine this is the temperature difference between cylinder temps and the ambient background.
diesels can operate hotter than petrol engines, since they don't pre-detonate like petrols do at high operating temps (pinking, iirc). bigger temp drop for the heat cycle means better inherent efficiency.
Posted : 30/09/2011 8:31 am
To make it simple, Diesel cars are more efficient, basically every £1.00 of fuel put into a Petrol about 30% goes to making the car go forward the rest is lost in heat. Every £1.00 put into a Diesel about 45% goes to making the car go forward, so less is lost to heat.... hence why Diesels take longer to warm up on colder days!!
Posted : 30/09/2011 8:38 am
I have a nissan diesel and i have no black smoke issues.
Posted : 30/09/2011 8:39 am
Having had a diesel Vectra, I can confirm they have more than just this in common with a tractor.
Odly, with the exception of the british public, does anyone refer to it as petrol? Even industrialy it's refered to as gasoline.
Posted : 30/09/2011 8:47 am
I think you have this the wrong way round? Diesel engines run about 200C lower than petrol engines but operate at higher compression ratios & are therfore able to convert more energy into forward motion, plus diesel whilst having the same calorific value of petrol (per kg) is about 15% denser, so more bang per litre of fuel.
Posted : 30/09/2011 8:58 am
Another factor that makes diesels more efficient is direct injection. You only need to inject the fuel you need to burn, whereas in a petrol you have to fill the cylinder with air/fuel mix so that it ignites - then if this is too much power you have to throttle it back which wastes energy.
As for the smoke - it's only bad when people tootle around town all the time. My diesels have always had lots of long trips and done some work, which cleans out any crud regularly. The Passat has never run so smoothly and cleanly as when I was in Germany doing lots of Autobahn.
My 1.9 Ibiza 105bhp wouldn't smoke at all no matter what I tried; the Passat can do a bit if I do lots of town driving then floor it suddenly. Globalti's Passat will have a DPF so no smoke.
Posted : 30/09/2011 9:11 am
I've got a 7 year old BMW 320d (no I'm not a sales rep!) and notice it smokes when I accelerate hard. Not loads but if the car behind has headlights on you can see it sometimes. I just assumed this was a combination of 'clearing it out' and burning more fuel.
So while we're talking about diesel, why is it more expensive than petrol now? I seem to recall years ago it was a good amount cheaper than petrol, is this because more people are driving diesels so 'they' have decided they can wangle more money from us or does it really cost more to produce (or is now taxed higher)?
I thought I read somewhere once that diesel is a by product of the refining process. If that's true (doubtful since I can't remember where I read it) why is it more expensive now?
Posted : 30/09/2011 9:14 am
[b]Smoking[/b] - largely down to the driver IMO. Mine smokes occasionally if you open the throttle sudenly. As someone posted above, diesels need to be worked hard from time to time to clear the soots out. It also helps to add some Redex diesel to the tank once in a while
[b]Gasoline[/b] - as much as I dislike Americanisims, "petrol" is a misnomer used by the British public. Petrol is short for petroleum, which covers a whole range of petroleum products. Gasoline is a blended fuel comprising a variety of different light hydrocarbon fractions from C5 to about C10.... and of course one of those blend components, C8, Octane gives it's name to the old octane rating
[b]Cleanliness and efficiency[/b] - It took me a long time to get a diesel, and it was a purely fiscal choice. As someone who works in the environmental industry I remain sceptical about the benefits of diesel over petrol. Tax and profits are a significant factor as far as I see it
There is always a light haze that you can see at night in the car behind's headlights.. I woudln't call this smoke really.
Have to pull you up on that one I'm afraid. Petrol is short for petroleum spirit ie something distilled from petroleum, which is not an unreasonable name. Next time you are at a garage look around you'll see some warning signs somewhere that say 'danger, petroleum spirit' or similar.
Diesel is worse for some pollution (NOx and particulates) and better for others (CO2 and hydrocarbons, both greenhouse gasses). So it depends which you consider important. If I lived in Athens I would not drive one because NOx and sunlight create smog, which is a terrible local problem there.
This is why petrol hybrids were invented, really - for the US market. The fuel economy of a diesel but with far less tailpipe pollution. And before anyone starts banging on about batteries being terrible things, find some real actual data about it. I'd love to see some.
Posted : 30/09/2011 9:22 am
Most diesel smoke is down to poor servicing. Diesels require a good, clean flow of air. If the air filter is blocked up, leak in the turbo charger/pipework or blockage i.e. EGR then it will overfuel creating unburnt diesel in the exhaust and smoke.
Diesel isn't a clean fuel like petrol and injectors and pumps can collect sediment causing poor injector spray and weak combustion so the fuel system needs regular, at least annually, to maintian efficiency. Products like Redex are useless on diesel fuel systems and need stronger products such as BG44 or Forte.
Posted : 30/09/2011 9:27 am
I'll look up BG44 and Forte, thanks. Definitely interested in keeping my diesel running nice and cleanly.
EDIT just looked at BG244, the first thing it says it helps with is 'hesitation and flat spots'. Well I'm seeing hesistation a couple of times every time I drive off, so I'll give it a whirl. Do you have to order it online?
Posted : 30/09/2011 9:30 am
Have run nothing but diesels for a few years now in our house.
Yes they smoke a bit when you boot it. It's just clearing out all the soot that's built up in your exhaust as you've been pottering along for a bit.
Top tip immediately pre MOT, give it a good thrashing (eg red-line it up a big hill in second) to get everything out of the exhaust system before. 🙂
Posted : 30/09/2011 9:35 am
This is what I was trying to describe and is just what I see, although not always.
I'm amazed nobody has picked up on the use of the word 'tailpipe' already so here goes....
Tailpipe? TAILPIPE? It's called an [i][u]exhaust pipe[/u][/i] over here you know. 😛
Posted : 30/09/2011 9:41 am
The usual reason for black smoke is the engine running too rich, i.e. not enough air to burn all the fuel going through. It can be down to problems with the engine, but you can make almost any diesel do it by labouring the engine. Putting your foot down pumps more fuel through, if you're in the right gear for the speed you're doing, no problem, if the gear's too high the engine will pump out black smoke until the revs catch up enough to send through enough air to burn all the fuel. Electronic engine management helps, but can't always compensate for a heavy right foot.
Posted : 30/09/2011 9:45 am
The modern ones shouldn't do it if they have a fap (or particulate filter) as this is ment to trap the particules but its basically unburnt fuel. I can just about get my auto diesel to do it by giving it a real boot full but its only mild compared to others. Most manual diesel will do it noticable when floored or as above if they have ablocked air filter or spilt turbo pipe and the air/fuel mixture is rich.
oh and fi the fap filters are why the paris dakar trucks no longer smoke when they are racing.
True - it's been a while since I've seen that in full!!
In my line of work it's always gasoline. To my embarassment I've even called it gasoline when paying 😳
I do use the diesel specific Redex
Posted : 30/09/2011 9:48 am
That's true. It's the emission of PM2.5 and NOx that we should worry about.
Posted : 30/09/2011 9:53 am
Twigged on last week why my windscreen was difficult to see out of at night. There was a film of oily, sooty, shit over the inside, which left me worried about how much has gone down my throat.
I have a diesel, but it has a particulate filter so I drive around guilt free. I reckon the vast source of diesel soot is coming from buses, which with their start-stop route and driver's tendency to boot it every time chucks out vast quantities of black smoke.
Posted : 30/09/2011 10:12 am
Busses have had DPFs for years I think. The new ones are very clean.
It's because the turbo is not spooled up. I think modern cars over-fuel a little bit to get the turbo spooled up faster when you boot it from low revs.. hence the little puff.
Posted : 30/09/2011 10:30 am
