Shimano Yumea Chain...
[Closed] Shimano Yumea Chain - worth it?
[#1460658]
It's time for a new chain. The current one hasn't stretched and I like to alternate 2 chains to keep the (XT) cassette and (Deore) rings alive for longer. Normally I use a SRAM 9 speed one but my LBS has got a Yumea for £25.
Very tempted. Anybody else had experience?
Posted : 30/03/2010 11:11 am
Mine looks nice.
Other than that, I haven't really felt any difference between that and the SRAM chain I used to run.
Apart from the fact it was part of the STW prize from a while back :mrgreen:
Posted : 30/03/2010 12:17 pm
At cost price, what have you got to lose? Use a Sram link to join it though.
Posted : 30/03/2010 12:20 pm
Of course it's not worth it. That's not the point of Yumea kit 🙄
Posted : 30/03/2010 12:22 pm
 Alb
£25 is a bargain and cheaper than srp on an XTR chain. The upgrades of a Yumeya chain are:
- Hollow pins to reduce weight, 10 grams less than XTR
- Ti-Nitrate plated inner plates to reduce friction for better shifting and improved durability. The Ti-Nitrate coating is also porous and holds lube for longer
Posted : 30/03/2010 12:52 pm
Do they have a lot of them at £25 and if so, where are they? 🙂
Posted : 30/03/2010 12:59 pm
They only had one, I've got it here now in its rather nice hard padded case.
I've come over all Gollum. I might not get round to fitting it, I might just leave it here on my desk.
Alb - Lube? You mean I've got to lube it?? Special Edition 3in1 for me then.
Posted : 30/03/2010 1:58 pm
Yes. Because you're worth it.
Posted : 30/03/2010 9:27 pm
I've just given it its first special lube.
Posted : 30/03/2010 9:31 pm
Deore rings and a Yumeya chain? Strange set up that, I can understand eeking out an XTR transmission, but with Deore/XT I'd be more inclined to run it into the ground over a year then replace it all! New chains never work quite as nicely on even slightly worn rings/cassettes IMO!
To answer your original question, the Yumeya chains are decent, the most worthwhile part of the group.
I just find Deore rings are better than anything else. A touch heavier maybe but long lasting and slick. XT cassettes similarly, and at £25 all I was worried about was compatibility.
EDIT - I just remembered the shop actually sold me an STX/RC granny back in December, now that's gonna be a unique combo.
Posted : 30/03/2010 9:41 pm
