Have had an annoying rattle on the roadie for a while now and have tracked it down to the ultegra cassette.
It’s seated on a mavic free hub.
The highest 3 gears/chainrings seem to have a bit of play in them. Not side to side but forward and back. There is probably about 3-4mm of movement.
That’s not normal is it!? I’ve tried taking it off (no sign of wear to the free hub and correct mavic spacer used) and reseating. It was quiet for about 5 miles but is back to rattling away again.
Is the cassette knackered? Is that what they do? Have recently replaced chain ( second chain on original cassette) and changes gear perfectly with no skipping under load etc. Very annoying if I have to change it for that.
MM
