Road Question - Cam...
[Closed] Road Question - Campag Veloce
[#2156352]
I have another Q - I have a Veloce 8 Speed setup - I need to replace the BB I think. I will prob have to remove it to answer my question but its a triple - 2 axle lengths are 111 and 115.5 - I guess I would be going 115.5?
Posted : 04/11/2010 10:55 am
If my failing memory serves me right, I think the axle length is stamped onto the right hand BB flange - might be worth just pulling the chainset off and seeing what is currently fitted. Probably will be the 115.5mm, but worth checking.
Posted : 04/11/2010 11:16 am
Brill - i'll go and check 🙂 Thanks Missing 🙂
Posted : 04/11/2010 11:22 am
No it only says the tpi 🙁 I'll get the triple anyway.
Posted : 04/11/2010 11:44 am
Erm why not measure it? (sorry if I have missed something). 115 does make sense though.
You "think" it needs replaced - why?
Posted : 04/11/2010 11:50 am
The creaking is still going on. I am convinced its either the BB or the axle interface. I have knackered the thread on the drive crank as the metal is old and soft trying it get it off with my crank extractor. I need to get a bit of wood and tap it off - I'll try that first but need to get the Campag BB tool and so for and extra £15 I can get a new Veloce BB. Its 3 years old but hasn't been ridden recently. I can use the spare BB eventually 🙂 If that makes sense ? It now creaks both sides and having had that on previous bikes I think I'm in the right area. I want to take the BB out anyway to clean and grease. So I can always send it back if its the wrong size - just wanted to get all the stuff I might need and do it all at one time 🙂
Posted : 04/11/2010 11:58 am
Aye OK well up to you still bet there's nowt wrong with the bb.
Oh and metal doesn't go soft with age 😉 ...you'll need more than a tap with a bit of wood to get the crank off, ideally a stein cutter & puller.
Quick fix...pull LH crank off, pull LH bb cup out, spray lube shell/thread interfaces, reassemble.
Posted : 04/11/2010 12:02 pm
Re the creaking - it's not the lower headset race is it? Sounds daft but it's one of those creaks that reverberates through the frame and often feels like the BB. I had the entire chainset/BB in bits and regreased trying to fix a creak once, it turned out to be the bottom cup of the headset and I've seen it on customers bikes too.
Posted : 04/11/2010 12:14 pm
Seems pretty much anything can cause a creak (tho rarely worn.corroded bearings).
BB/pedal/chainring bolt threads still the most common cause OME/O!
Posted : 04/11/2010 12:26 pm
Yup cynical - sorry bad terminology - I think I should have said it was corroded as It stripped the thread out 🙁 BTW - checked crank bolts and pedals in the last 2 weeks 🙂
I'll bash the inside of the crank with wood and see if I can at least loosen it - I was def going to take the non-drive crank off (unless I also strip the thread off 🙁 )
I expect the BB is OK but having been a boy scout I am always prepared 😉
Crazy - def not the headset as removed and cleaned when I got the bike 3 weeks ago as had to setup the ride position from sratch 🙂 Will def look again though 🙂
Posted : 04/11/2010 12:28 pm
 aP
I had a really annoying creak that turned out to be a cable ferrule rubbing against a cable stop. Took 4 months to track down and required removing BB, headset, peadls, pivot bolts and bearings.
Posted : 04/11/2010 12:35 pm
I think I have checked all the easily accessible sites so far - the BB is left 😉
Posted : 04/11/2010 12:45 pm
Campag triples are 115mm axles apart from Chorus and Record IIRC which were 111.
Posted : 04/11/2010 2:05 pm
Thanks breathe - 115 ordered and probably surplus 😉
Posted : 04/11/2010 2:56 pm
BTW my clicking/creaking is gone! Replaced BB which was rusted up and very rough with little bit of play - new bb, cleaned threads in BB, cleaned cranks. Had to remove the drive crank with a chisel as a wedge driver but came off a treat 🙂 Reckon it was either the bearings or poss creaking from the rust between the non-drive sleeve and BB shell? Anyway I am tickled pink 🙂
Posted : 06/11/2010 5:59 pm
it's never the bearings!
Posted : 06/11/2010 6:23 pm
I have to disagree! And the BB needed replacing as it was def on the way out - rusty water coming out of it! BTW I have been doing my own servicing on my MTB's since I have been mountain biking (1992) and been road biking now for 5 years so I do have some experience of these sort of things Cynic-al 🙂
I am not putting the old BB back in to prove the point however 😉
Posted : 06/11/2010 6:34 pm
Worked in bike shops on and off (mostly off) since 1988.
It's appealing to think the bearings cause it but there's more logic to other causes.
Posted : 06/11/2010 6:38 pm
Point taken ! Still on my list of possibilities 🙂
Posted : 06/11/2010 6:45 pm
