Ride it , Manual it...
[Closed] Ride it , Manual it. or jump it.
[#1573853]
Here's a pic from an XC race I did this weekend, my technical skills need some work and I need a bit of a confidence boost. We had this bank to ride down on every lap and every lap I minced down it. Looking at this pic I'm amazed I didn't go over the bars. So I'm after some constructive criticism. Should I just ride something like this, manual it, or even try to jump it?
Posted : 04/05/2010 8:44 pm
MTFU and Superman seat grab it! Mad skillz
Posted : 04/05/2010 8:46 pm
Roll it.
And your peak has fallen of your helmet 😉
Pre-jump it, racer stylee...
Posted : 04/05/2010 8:47 pm
Sorry, no idea!
The bit of dirt 3 feet to the right looks a nicer option though 🙂
Ride it, but get yer arse off over the back!
To be honest its the death grip on the bars that has probably saved you. One touch of the front brake and say good bye to your teeth.
Would just say weight lower to your back wheel and further back.
You should be able to move back and down which will lift (unweight) your front wheel when it gets to the bottom
Wouldn't jump it. I'd keep it on the ground and try pump out of the bottom
Posted : 04/05/2010 8:49 pm
Posted : 04/05/2010 8:50 pm
Prejump and pump it for speed and control.
Posted : 04/05/2010 8:52 pm
you're assuming that people on here actually ride...
Posted : 04/05/2010 8:54 pm
Roll it - manual it and you're likely to land on your ass. Jump / drop it if the transition, run in and run otu allow but from the photo you can't really tell but that would be a big drop to land.
I'd say roll it but as the guys above have said keep your weight back. I'd also rotate your brakes up a bit to stop you going over the bars - luckily your not using them in the photo.
rolling it is fine, your weight is just a bit far forward I think.
Jumping is going to depend on how flat your run out is.... jump to flat and your light weight xc bike won't be thanking you!
Pump it.
Posted : 04/05/2010 8:56 pm
 devs
I have a very similar drop on my regular route. I drop it unless I'm on the bike I would use as a "race" bike with the saddle at "race" height. The trouble I then have is that I can get over the back wheel but my baggies catch and then crush my nuts. So, in answer to your question, drop it but wear lycra!
Posted : 04/05/2010 8:57 pm
Fair play to you for throwing the camera with the self timer going at just the right spot and still getting your hands back on the bars for the drop.
In the event that it was someone else taking the pics, what do their pics show the rest of the field doing? Looking at the pic though, there seems lots of scope for getting your shorts a lot closer to the tyre and the saddle into your midriff.
Disclaimer: I am not a good rider and you should not take my advice.
cant see the height but looks about 5 foot i suspect - could be wrong ...
dont think your xc bike would look like much after 5 laps jumping that - to what looks like flat
if it was me id probably pre jump onto the downslope if its a fast section or just weight transfer if its not overly fast - you do look to have been carrying some speed
Posted : 04/05/2010 8:58 pm
As above, roll it - but unweight over the lip and pump down it and through the transition for the free speed boost!
Posted : 04/05/2010 8:59 pm
I don't even think your weight is in that bad a position just looks like you have come into it at warp factor 11!! I'd either role it or if travelling at a high speed I'd drop it with the back wheel just tracing the trail if you understand.
Posted : 04/05/2010 9:00 pm
Cool photo by the way.
Posted : 04/05/2010 9:02 pm
 tron
I'd be pushing the front wheel down into it, then rubbing my knackers against the back tyre.
Prejump and land on the down slope if you can. (practice on something smaller tho)
or just roll it if you're more comfortable with that.
Posted : 04/05/2010 9:03 pm
pre jump before you get to the lip and land on the downslope, especially if its a longer drop.
Get to a bmx track asap 🙂
Posted : 04/05/2010 9:04 pm
It was about 5 to 6 foot with a fast flat run in and the run out sloped away. I got faster on it on each lap just felt I could be doing it better. No chance of touching the brakes though.
Need to practice getting my weight further back.
Posted : 04/05/2010 9:07 pm
 AJ
I agree your not in a bad position for the slope your on, i assume that your body weight moved to suck up the transition?
The fastest way would be to suck up the lip and pump the down slope and then zoom away at a million miles an hour
Posted : 04/05/2010 9:09 pm
The guy in the following photo to yours does seem to have weight further back and lower, though it might be a bit deceiving as he has the near leg back. No baggies to catch though.
[url= http://www.guernseyvelo.org.gg/default.asp?pageMarker=singlePhoto&photoID=4272 ]Rider 402[/url]
Posted : 04/05/2010 9:15 pm
 jedi
1st thing, cover your brakes.
look further along the trail.
drop, or roll it. the choice is yours. if rolling it can you roll it by carving down it?
Posted : 04/05/2010 9:25 pm
360 off the lip ?
Posted : 04/05/2010 9:28 pm
I know what your problem is. Those XT wheels are too light, causing you to leave the ground at awkward moments.
Posted : 04/05/2010 9:46 pm
stop, review your line, pad up, um and haw, then walk it.
Posted : 04/05/2010 10:15 pm
Lol. The standard STW method?
Posted : 04/05/2010 10:22 pm
lol
lean back 😀
Posted : 04/05/2010 11:19 pm
 Olly
your all wrong.
the line is clearly just to the right of where the rider is spooning his way down the bank. take the longer route, it looks loads quicker.
i defy anyone who suggests prehopping that to ACTUALLY do it.
the transition is far too sharp.
Posted : 04/05/2010 11:34 pm
loving the ideas folk are giving you! pre jumping it lol.take a look at the conditions he was racing in along with the bike fs.
the seat is at xc height so its probably a good bet to slow down a little and stick to the ground a bit.carry on doing that and you`ll stress yer bike out. fine if yer riding a heavy duty bike with the seat down but its a bit on the edge by the looks of it. last thing you want to do is end up completely out of the race so i would slow it down a tad!
Posted : 05/05/2010 12:26 am
<makes note to remind himself to rotate his rear brake lever on bmx upwards to half his chances of going over the bars at the next race..
::rolls eyes and heads to bed::
Posted : 05/05/2010 12:32 am
By the look of the photo your weight was forward of the BB and as a result it looks like your back wheel was unweighted/lifting whilst the front tyre was under a lot of compression whilst the fork was not.
I'd do what Jedi says and next time look into the next section; let the bike sort it out, you obviously made it each lap so it must be ridable and you will move your weight back naturally if you pump the downslope for speed.
Posted : 05/05/2010 1:00 am
Looks pretty droppable to me if you can carry the speed into the launch.
Posted : 05/05/2010 1:05 am
Martin - I'm talking MTB and try it before commenting, you may like it 😉
Posted : 05/05/2010 6:59 am
ok - ill remember that next time - you can only prehop on a "hardcore bike" .....saddle up doesnt make you rigidly stuck to the saddle - you can still get over the back wheel - the suggestion of pre hop isnt to hoick the thing 3 foot into the air - more to un weight the front wheel to a manual then flick the back up at the last min to match the down slope as the front end comes down , its one of my favorite methods of riding things like this - done right it looks stylish as **** , droping it just looks bullish and is gonna result in a busted bike in an xc race !
id love to see the state of my xc race bike after dropping that for a few laps - 24 spoke wheels ..... and the ops bike doesnt look much heavier duty !
Posted : 05/05/2010 7:56 am
Just mince it, like the majority here would. 🙄
Posted : 05/05/2010 8:09 am
Bruneep, 2 types of people in the world .... neeps ; turbo mincers : murray !
Posted : 05/05/2010 8:13 am
d?
Posted : 05/05/2010 8:16 am
I'd probably try and manual over the lip, roll down with my front wheel just in the air and try to land flat, hard to tell without being able to see the top of the jump though.
Posted : 05/05/2010 8:29 am
rider 402 must have little fingers of steel - it's all he's holding on with.
I'd just mince through the best I could and probably get my weight a bit further back than you did in that shot.
Posted : 05/05/2010 8:35 am
This forum needs more of this!
Posted : 05/05/2010 9:21 am
