Have a set of 2011 RS Revelations 150mm RLTi Dual Air’s. This is my third set of revs and I have the u-turn version on my hardtail. However, I have an issue with the RLTi’s in that they suck down into their travel if the negative air pressure is even around 75% – 80% of the positive. I’m aware that increasing the negative air spring has this affect, however you usually have match or exceed the +’ve psi for the to happen.
I have lowered the forks from 150 to 140 but can’t see how that would affect this. If +’ve and -‘ve are equal then they suck down around 10 – 15 mm. Is this a characteristic of the RLTi’s or do they need to go back for a warranty job ? My team u-turns sink down a couple of mm but nothing like these.
Other options are to return to 150mm and with them sitting down 10mm I achieve the 140mm that I’m after, or decrease -‘ve until they sit at 140mm but this will surely affect small bump sensitivity ?
Any advice welcome ?
