Removing car sticke...
[Closed] Removing car stickers - any tips?
[#457702]
As per the title really. Looking to remove old 'baked on' stickers from the windows and bodywork of my new(ish) van. Thought (er..was hoping) they'd just peel off 😕 how wrong was I !!
Posted : 08/04/2009 1:27 pm
Napalm?
Posted : 08/04/2009 1:28 pm
I always used a hair dryer gently-especially on paint.
Warm it up gently to warm the glue.
Then any residue left after peeling it off-use Mr Sheen. Spray to a foam and leave for a minutes then polish off.
Posted : 08/04/2009 1:31 pm
lots of glass cleaner and a brand new single sided razor blade. I learnt this whilst as a student working for autoglass - used it to remove the labels from windows that i fitted.
Will work fine on glass -not sure about what to do on the bodywork though
Posted : 08/04/2009 1:43 pm
Thanks for the advice (off to pince the wife's hairdryer 😮 )
Posted : 08/04/2009 3:01 pm
If it's just vinyl graphics then a hair dryer/hot air gun will do the job nicely. Then wash and a polish or 2 to remove the residue glue.
Posted : 08/04/2009 3:25 pm
I took a load of them off my van using an air powered die grinder with a 4ins rubber wheel bit in it,a garage might be able to supply the air.(contact a signwriter for the bit you need)
I would avoid using a stanley blade as you will end up damaging paintwork,glue can be removed using a cellulose agent like preptone or there are some specialist glue removers on the market that can be sourced from automotive paint suppliers, (yellow pages)
Posted : 08/04/2009 8:58 pm
Hairdryer,as above.
Remove the remaining residue with 'Autoglym Tar & Glue Remover',available from all good car accessory shops(or Halfrauds).
Posted : 08/04/2009 9:01 pm
hairdryer is good,
residue can be removed using a caramel wheel on a drill (ebay/google for one)
Posted : 08/04/2009 9:03 pm
