Recommend me a Spri...
[Closed] Recommend me a Sprinkler
[#4008729]
I will be to blame for all the hosepipe bans in the Country! 😈
Newly laid lawn (4 days old), is getting dry and two hours with a hose is too long!
Looked at the Hoselock Aquastorm things..
Lawn is probably 5x7metres, rectangle shape. How adjustable are those sprinklers? They say 13x14m... I only want to water my garden, not the our neighbours too! 😯
Posted : 25/05/2012 2:41 pm
if you want to do it right you could go the whole hog and install hunter or rainbird pop ups from a waterbutt and pump running from a controller. (however I have a hoselock multi garden sprinkler on hose and sprays water as expected 🙂 )
Posted : 30/05/2012 5:11 pm
Those red bits (from memory) alter how far the centre bar tilts, theoretically you could set it against a wall and adjust it so it would stop at vertical and not get the wall wet, and still reach across the garden.
Length wise, you'd have to turn the water pressure down.
Once you set it up, run it after dark to avoid evaporation (and tutting between your neighbours)
Posted : 30/05/2012 6:03 pm
