Quick Chain Replace...
[Closed] Quick Chain Replacement Question - save me from my own stupidity!
[#2623815]
So I'm replacing my Shimano chain with a KMC jobbie which joins with a missing link. Am I right in thinking I match the chains up then take one extra link off the new chain to allow for the missing link? 😕
Sorry...this is probably, like, duh to some of you 🙂
Posted : 02/04/2011 2:05 pm
 nuke
Old chain will be stretched so the new chain will end up longer than it needs to be.
You'd be better doing the normal method of putting the new chain around the largest front ring and around the largest rear sprocket (not through the rear mech) then plus two links. It gives a good starting point and then you could reduce further if required.
Posted : 02/04/2011 2:08 pm
Erm...it might be a case of replacing slightly borked new chain with newer chain 🙂 They're identical in length. Old chain has only had a few 100k pre-borking.
Posted : 02/04/2011 2:13 pm
 nuke
You can't have borked a whole chain though...can you? Admittedly I've borked chains before (bent links from chainsuck) but I'd just removed the dud links and connected it back up...unless the rear mech is jamming when shifting to the lowest gear because the chain is too short, it'd be fine.
Posted : 02/04/2011 2:16 pm
I have a bit of a chain cleaning fetish - I like to be able to take chains off when cleaning the bike - hence if I get a bike with Shimano chains, I tend to replace them with removable link chains. It's just been a while since I did it.
Posted : 02/04/2011 2:19 pm
Do it as you said. That way the worst you can do is make it a bit too long. You can always shorten it.
The round the biggest sprockets is fine for a hardtail. With a susser you need to know if you might get chain growth.
Posted : 02/04/2011 2:20 pm
It's a road bike 🙂
Posted : 02/04/2011 2:21 pm
Why not just split the shimano chain and fit a powerlink? I guess if it's a 10 or 11 speed chain that may not be appropriate though.
Posted : 02/04/2011 2:40 pm
It's a ten-speed geoff.
Can I do a powerlink on that then...say a SRAM 10 speed jobbie?
Posted : 02/04/2011 3:29 pm
SRAM "quick-links" for 10-speed are called PowerLOCKS and they are a use-once option.
Posted : 02/04/2011 3:32 pm
Nope 🙁 Only us luddites still on 9sp road bikes.
Posted : 02/04/2011 3:54 pm
If it helps at all the split links on KMC 10sp road chains are removable.
Posted : 02/04/2011 4:19 pm
Get a Connex link on it. They're reusable and much easier to remove. They only go on one way round so read the instructions!
Posted : 02/04/2011 4:21 pm
So let me get this right then fellers; I can remove a Shimano link and replace it with a Connex jobbie? 🙂
Posted : 02/04/2011 4:34 pm
Cheers Geoff. Am on phone so will check that link later. I now have two chains for the rOad bike then. Yay.
Posted : 02/04/2011 4:47 pm
Lots of options for 10 speed 'powerlink' options. I had some KMC ones.
Posted : 02/04/2011 7:53 pm
