Hi guys,
I have shortened the cable as it was too long, connected it back and it will not "click on" to lock out the forks. Any ideas what could be wrong? would that be a problem inside the fork or the lever?
thanks
Hi guys,
thanks
assuming it all worked before hand likely to be the cable - you did attach it correctly ie with lever and lock bit in matching positions?
Is it warm enough for you to ride yet
