Plasterboard wall a...
[Closed] Plasterboard wall and hanging shelves question
[#1067612]
I need some advice hanging some shelves on a plasterboard wall... The shelves are in the kitchen and will be holding around 30kg of kitchen guff like plates, pots/pans etc.
I've discovered that the plasterboard to which I need to fix the shelves is sitting about 20mm away from the masonry. I initially was going to use some molly 40kg rated expanding anchors but these are about 50mm long. The shorter ones are only rated at 10kg.
So what are my options for anchor bolts that can be installed in narrow spaces?
I've just been reading about springloaded toggle bolts, but worried that the toggle 'arms' won't have enough space between the plasterboard and masonry to expand fully when inserted...
Posted : 23/11/2009 9:38 pm
look at this;
http://www.diydoctor.org.uk/projects/fixingtoplasterboard.htm
Posted : 23/11/2009 9:44 pm
 Taff
If your blockwork is only 20mm behind the plasterboard then I would use the long wall plugs. I can't find quite the right ones but they look like [url= http://www.screwfix.com/cats/101151/Fixings/Window-Anchors ] this [/url], They will cope with the weight but make sure you get over 50mm penetration. If you go with expanding bolts you hae to be careful witht the tension. If you have 7N blocks you and don't drill far anough in then you're more than likely going to ping the face of the block off instead.
Posted : 23/11/2009 9:45 pm
 Taff
He's got dot and dab by the sound of it so may not have enough space for self expanding plasterbaord fixings.
Posted : 23/11/2009 9:46 pm
First what are the shelving brackets look like?
Or what type of shelving you putting up.
And how many brackets over the length of the shelf
you going to use.
Is it one or two platerboards thick on the wall
Posted : 23/11/2009 9:47 pm
several options
Toggles are only as good as the security of the plasterboard glue or screws into the wall battens DO NOT RISK IT
Drill through the plaster board into the wall push a Fischer (better than rawlplugs) plugthrough the plasterboard and into the brickwork
or
cut the plasterboard and fit battens to the wall then attach onto the batttens
Have a look at the Fischer Fixings website
http://www.fischer.co.uk/desktopdefault.aspx/tabid-1777/
Posted : 23/11/2009 9:48 pm
Use frame fixings, theyre got quite long sleeves and long screws,apply some silicone sealant in the holes and theyll hold like crabs on a prostitute.
Posted : 23/11/2009 9:49 pm
Ok, so you wouldn't try to secure to the plasterboard alone, but penetrate right into the masonry? Wouldn't tightening the shelf bracket against the plasterboard into the masonry distort the board?
(By plasterboard I mean dry stud wall)
The masonry is a dividing wall in a tenement, I wouldn't want to go through to next door!
Posted : 23/11/2009 9:50 pm
[i]First what are the shelving brackets look like?[/i]
http://www.ikea.com/gb/en/catalog/products/10136135
[i]And how many brackets over the length of the shelf you going to use.[/i]
One each end (they cap the end of the shelf material
[i]Is it one or two platerboards thick on the wall[/i]
One, 13mm thick
These are the mollies I was going to use
Project - these badboys?
Posted : 23/11/2009 9:56 pm
It's almost worth removing the plasterboard where your shelf support will go and building a wooden frame behind them. You can't put much compressive force on plasterboard, it will eventually crush.
Perhaps a pile of washers on top of the frame fixing to bring the shelf bracket level with the surface then tighten massivly.
Posted : 23/11/2009 9:59 pm
mikey, that's not going to happen - the wall's just been tiled and painted.
Posted : 23/11/2009 10:01 pm
 Taff
The second of the fixings.. don't use the expanding steel ones. They will go into the nasonary but won't expand where the plasteroard is. they're meant for this purpose so the create a neat fixing and don't damage the facework
Taff, do you think I can penetrate the masonry with the frame fixings, without supporting the bracket area behind the plasterboard? I'm worried that weight added to the shelf will distort the plasterboard...
Posted : 23/11/2009 10:06 pm
Lee thats the ones, but make sure that the holes in the shelving are big enough to take the screw.
Also check there are no cables,or pipes,remember some water pipes are now plastic,so they dont show up,with a metal detector.
30kg of plates and pans,get a divorce,and you can live with one sausepan and a few paltes, i do.
Posted : 23/11/2009 10:09 pm
30kg ? 😯
Brackets like this ?
Yep, I'd be worried too. I reckon your brackets will pull straight through the plasterboard (or push through under the 30kg weight)
Can't you put plates pots and pans in a base unit and leave the shelves for light items ?
Posted : 23/11/2009 10:14 pm
haha ernie, well the brackets are rated at 30kg but yeah it might be a bit excessive!
Posted : 23/11/2009 10:28 pm
If the boards been dabbed correctly, there shouldnt be massive voids behind the board, so they shouldnt distort under the pressure of the bracket. You may even be lucky and hit a dab with both brackets.
If the PB is attached to the masonary by a 20mm batten, could you try and locate these and fix through them??
Posted : 23/11/2009 10:46 pm
Why not use SPUR adjustable shelving that will give you more anchorage points.
Posted : 23/11/2009 10:48 pm
hector, that would be ideal, but the shelf location is limited to the one place.
i think taff's solution of securing into the brickwork behind the pb is the best. i'll just make sure the plates are in the bottom cupboard ;o)
Posted : 23/11/2009 10:49 pm
Taff, as long as I make sure there's that 50mm penetration into the masonry, is there anything in particular I should look for in the long frame fixings?
http://apps.fischer.de/poc/default.aspx?page=layer&sprache=EN&ekat=$EKAT-HK-EN&kat=$MART-HK-$MKAT-HK-$MPG-G2
Posted : 24/11/2009 12:14 am
4 inch 10s into brown plugs, and you'll never pull the ****ers out.
Mind, you'll probably pull the brackets straight through the plasterboard 😐
Posted : 24/11/2009 12:18 am
Firstly if its a divided wall between two properties the combined wall thicknesses will be about two bricks thick, around 9 inches.
Drill your holes out with a tile cutter followed by the masonary drill bit.
And I will use two brown raw plugs per hole and use what ernie_lynch says.
But nothing less than 110mm length as you have a 20mm void and losing
that much of the screw length.
Posted : 24/11/2009 7:26 am
 aP
Isn't 9" single brick?
Posted : 24/11/2009 7:35 am
A supporting brick built wall or an old house is generally built two bricks thick.
Posted : 24/11/2009 7:46 am
 aP
Strange, we call 4" half brick.
Posted : 24/11/2009 7:52 am
I had exactly the same issue...dot and dab plasterboard over brick with a small void. I'd put the plasterboard up the plan was always just to go straight through into the masonry.
I used the IKEA Grundtal shelves, got pots and pans hanging off one with lids slotted in the bars on top, other has utensils and camelbacs hanging off and recipe books on top.
I just used long beefy woodscrews, hand twisted a brown rawl plug on the tip of the screw, took a depth reference so I knew when the rawl plug was fully home, then hammered them in to my drilled holes to the correct depth. Then screwed them in. They were nice and tight, got no worries 🙂 Make sure the hole is a smidge undersized, you don't want the rawl plug twisting. If you've tiled over the actual bit where the shelves are going, I'd be very careful when tightening up! I've even cracked a tile when tightening a socket cover.
Posted : 24/11/2009 9:13 am
If it's tiled over then the tiles will take the moment/load of the barcket, reducing the risk of punching through the plasterboard?...
maybe.
Posted : 24/11/2009 9:42 am
cheers spooky, that's exactly my problem, but the plasterboard was already up so i didn't know what was behind it! it seems like every fitting we put into the walls gives us nasty surprises ;o)
personally i'd prefer the plain brick walls (and it would make things like this so much easier).
how long was the rawl plug you used - i'm imagining those 1" brown ones... but have my eye on the frame fitting plugs taff recommends above.
mugsys, the bracket area isn't tiled; it will be sitting straight on top of the plasterboard. the rest of the kitchen has been though, so i can't take it all off!
Posted : 24/11/2009 10:00 am
you probwant to use some big rawl plugs rather than framne fixings. IIRC all frame fixings are hammer in whihc is fine if your securing a timber frame, but may well screw up your shelving brackets. Youve much more control with a screw. As peoplpe say if your wall is a bit rubbish use a mm smaller drill bit .
Posted : 24/11/2009 10:48 am
I'm pretty sure I just used the 1" brown ones. Obviously you will have to hunt around to find a screw head that fits nicely into your bracket...no point have a huge brass pozi head sitting proud of a bracket designed for a much smaller screw! Thats partly what is nice about the Ikea brackets, the countersink is nice and big.
Posted : 24/11/2009 10:54 am
I have to hang a radiator off a dab & dobbed section. I guess I can mount regular rawlplugs into the PB adhesive as it seems hard as concrete?
Posted : 24/11/2009 10:56 am
Pieface you should get fixings with the radiator
just use the ones provided r buy longer fixings to componsate
for the gap.
Posted : 24/11/2009 11:34 am
dry lining plasterboard is a pain in the hoop, eh?
Posted : 24/11/2009 11:38 am
 Taff
Mugsys_m8 - you sound like an engineer... careful Lee he might start telling you to put in steel columns next!
Posted : 24/11/2009 2:55 pm
If it's tiled over then........
I wasn't paying attention - I didn't realise that it was a tiled wall. Yep, the tiles will stop the brackets pulling through. Although if the screws are done up nice and tight to take 30kg, it'll probably crack the tiles 😐
I would keep the shelves for the salt and pepper pots, mustard etc. If you really want to place heavy items high up, then I would buy some wall units - not selves. IMHO
Posted : 24/11/2009 6:21 pm
