Pinnacle Arkose 4 f...
[Closed] Pinnacle Arkose 4 front Hub Bearings? Help please.
[#7638142]
After 6 months of use the front KT hub bearings have given up on me.
Phone evans in birmingham whom i bought the bike from and they were about as helpful as a fork serving up gravy. They said they wanted to see the wheel first before they could tell me how i go about buying new bearings.
Took the wheel to my local halfords and they were just the same. They said they only service caged bearings. Says a lot for boardman.
Im awaiting response from pinnacle themselves after emailing them last night.
Not happy really with bearings only lasting 6 months and no one can tell me how to go about repairing them. Rubbish unbranded hub i think.
Anyone help me?
Posted : 10/02/2016 10:15 am
You could do what I did when I needed to source some new forks after a bash:
1) Try for ages through various channels at Evans to get some.
2) Put a bad review on the Arkose 4 page on Evans website saying spares are unavailable
3) Wait for product manager to contact you, who will solve your problem the next day.
Or - just leave your post here here, jameso is the product manager and I'm sure he'll be along shortly, the gent that he is.
Posted : 10/02/2016 10:22 am
If its a sealed hub like Novatec, then i'd guess that either the end caps just pull off, or you can stick an allen key in each end and unscrew them so you can see which bearing you need.
Posted : 10/02/2016 10:25 am
Are they not cartridge bearings? Bash them out, measure them up and buy some replacement sealed cartridge bearings?
Posted : 10/02/2016 10:26 am
any decent LBS should be able to swop these over for you
Posted : 10/02/2016 10:34 am
I have unscrewed the the 2 end caps and now left with the bearings completely visible and a 10mm allen key shaped piece in the middle that goes straight through to the other side. Ive had an allen key in each side and you cant undo anything.
Posted : 10/02/2016 11:06 am
You went to Halfords and Evans. Is there a reason you are not trying normal bike shops?
Posted : 10/02/2016 11:10 am
Same as JT said I just take mine out, measure them and order a std bearing to match that as they're all stock sizes. Will need to get a book out to look up the size of that one when I'm in the office later this eve, agreed it's useful to have new ones ready to go to do the job in one go.
Posted : 10/02/2016 11:53 am
Bongohooha you would think evans would know something about there own bikes. Especially when they recommend you a bike.
Halfords need to hurry up with times.
Posted : 10/02/2016 11:56 am
Jameso ide love to take them out but apart from bashing them out i cant see another way.
Posted : 10/02/2016 11:58 am
I wouldn't expect them to know bearing sizes that readily to be fair. Goes for any shop. Some will, some won't, it's them knowing who to ask to get that info that's more important.
Posted : 10/02/2016 11:59 am
You do bash them out, carefully.
Jameso
You would think they could look at another Arkose and get back to you. Im sure there is another Arkose in the birmingham store.
Posted : 10/02/2016 12:33 pm
If the bearings are visible then you should be able to read the part number of the seal?
Posted : 10/02/2016 1:26 pm
I've checked the parts info and helpfully the manufacturer doesn't list the bearing size .. so if it's not visible on the bearing and you don't want to remove them first I'll need them to reply to be 100%. At shows and out of the office this week so no bike on hand apart from the 2016 4 spec.
Posted : 12/02/2016 1:44 pm
If you don't know how to take the hub apart to see what size the bearings are Then how will you replace said bearings if Evans do tell you which size bearings you need?
Posted : 13/02/2016 10:43 am
Most probably Novatec hubs. 6001 rs for the bearings?
Posted : 13/02/2016 10:51 am
If you can see the bearings the code should be on the seal. Just order 2 new ones from a decent ebay supplier then watch a youtube vid to see how to tap them out and new ones in. 10 minute job once you have done it a couple of times. Or take it to a bikeshop and expect to pay £35 ish.
I know it seems annoying when you phone the shop but there are so many variants they will want to be sure
Posted : 13/02/2016 11:03 am
Find a shop that know what they're talking about - most front hubs use much the same construction but there are a range of bearing sizes. If you've been riding the bike all winter in filthy conditions or used a jet wash, then 6 months isn't unusual. Replacements bearings are a few quid each - drift the old ones out and press them in on the outer race e.g. socket.
Posted : 13/02/2016 11:16 am
I think you can't see the code on the bearing, so get the end caps off, measure the outside diameter of the bearing, the diameter of the hole in the middle and the width, (which may admittedly be tricky, I'm sure you can estimate closely enough)
Put the size in [url= http://simplybearings.co.uk/shop/ ]this website[/url] and bob's your mother's brother. You'll need deep groove ball bearings, and look for ones with the suffix 2rs, (2 rubber shields) Then all you have to do is tap the old ones out, new ones in, (without resorting to hitting the inner race which will knacker them) and you're on your way.
Posted : 13/02/2016 11:30 am
[URL= http://i1162.photobucket.com/albums/q525/Pictonroad1/E2EAEBFF-1A2B-4404-BE8A-8B8B4E8FEC62_zpsrkoqgb26.jp g" target="_blank">http://i1162.photobucket.com/albums/q525/Pictonroad1/E2EAEBFF-1A2B-4404-BE8A-8B8B4E8FEC62_zpsrkoqgb26.jp g"/> [/IMG][/URL]
Is the hub the same as this?
[URL= http://i1162.photobucket.com/albums/q525/Pictonroad1/9C27D6B2-8523-4207-B057-C91249546CC8_zpsksmt1nkf.jp g" target="_blank">http://i1162.photobucket.com/albums/q525/Pictonroad1/9C27D6B2-8523-4207-B057-C91249546CC8_zpsksmt1nkf.jp g"/> [/IMG][/URL]
[URL= http://i1162.photobucket.com/albums/q525/Pictonroad1/F12D067F-E80F-4F28-90E8-04E2F4022682_zpsmrifgkzp.jp g" target="_blank">http://i1162.photobucket.com/albums/q525/Pictonroad1/F12D067F-E80F-4F28-90E8-04E2F4022682_zpsmrifgkzp.jp g"/> [/IMG][/URL]
I've only ever removed hope and shimano bearings, can't say I know how to do these and it's not instantly obvious.
Posted : 13/02/2016 9:36 pm
Quick google of the model number stamped onto the hub there throws up various results e.g. http://www.o-lite.com.tw/pro.php?m=d&pid=29&cid=15&f=4
Posted : 13/02/2016 9:45 pm
[url= http://www.o-lite.com.tw/lib/dl_file.php?dir=catalogues&filename=zNSdvegQT4YcNa%2F8OpF%2BDr7emCdqIQ&o_file=2013-INSTRUCTION.pdf ]rear hub instructions?[/url]
Edit- that's no help.
How DO you get to the back of the bearings jameso?
Posted : 13/02/2016 9:52 pm
If its like some fulcrum hubs I had, then use the aluminium spindle to drive the bearing out directly. It may have a shoulder behind the bearing. Remove one side, re-insert spindle and drive out the other side.
Posted : 13/02/2016 10:28 pm
Yup - like a lot of KT derived hubs inc. nukeproof generator, superstar Tesla etc, its probably a case of using the shoulder on the inside to drive it out, by tapping the axle through. I normally use a nylon mallet for this.
Worth looking on the KT website I reckon
Posted : 14/02/2016 12:37 am
Your hub is part of a bike-its a collection of mechanical bits. Get your hands dirty and learn to fix it yourself or take it to a REAL LBS and pay them. Either way stop crying about consumable components wearing out.
Posted : 14/02/2016 12:48 am
While I am in no way siding with the OP, why should he have to do either of those things? Evans should be able to sort him out.....and yes, this does mean he takes the wheel to them. I would expect them to lend him one to use in the mean time seeing as they don't know the bearing model of a bike they sell.
Posted : 14/02/2016 10:44 am
Hi Jacob, the bearings are 3x 6802-2RS. There's one on the drive-side and two on the disc side. Drift the non-disc side bearings out first by simply tapping the oher end of the axle (plastic mallet or similar to protect the axle end). Then use the disc-end of the axle (longer space between end and bearing seat shoulder) to drift out the 2 bearings on the disc side.
Sorry it's taken a few days to get this confirmation sorted.
A few pics to help clarify,
Posted : 16/02/2016 5:28 pm
Jameso, you're a legend. Bookmarked for when mine need replacing! Same size in the rear??
Posted : 16/02/2016 8:47 pm
OP, just a bump in case you missed this.
Sheeps, not heard from KT yet. There's online details of how to remove them, a tech section of the same in the catalogue and yet no bearing sizes listed.
Posted : 20/02/2016 4:58 pm
Did this get it's new bearings in the end?
Posted : 01/03/2016 9:18 pm
