Paint stripping fra...
[Closed] Paint stripping frame to raw
[#3557057]
I've never attempted anything like this before but I've decided to paint strip the horrible day-glo orange from my commencal supreme and go 'raw'.
Any advice on the best way to strip the paint and how to treat the alloy once stripped?
Posted : 12/01/2012 2:07 pm
Professionally? That'll be powder coat not enamel and i' m not convinced you wont be risking harm to the frame by abrasives or chemicals.
Posted : 12/01/2012 2:41 pm
 juan
elbow grease + niroumours or caustic soda. Then PU lacquer or just elbow grease again. Now as why someone want to remove the paint from one of the sexiest colour on a bike, this is a different matter.
Posted : 12/01/2012 2:44 pm
Commercially available chemical strippers are highly unlikely to harm the frame. Using something like Nitromors you'll need to dismantle the frame completely and give yourself half a day to remove the paint. The bulk will/should come off easily; paint around welds will need extra applications of stripper. Aluminium does most of its oxidising withing minutes of being exposed, so a bare/polished frame finish will be easier to maintain than one with a clearcoat finish.
For what it's worth, I've done three frames: one HT and two FS.
Posted : 12/01/2012 2:47 pm
I've just had my paramotor sandblasted and re-powdercoated for £150.
He was cursing a bit as old powdercoat doesn't just blast off - it melts off, which is really slow.
Looks ace though.
Posted : 12/01/2012 2:53 pm
nitromors..
then polish the frame...
both take ages... and ages and ages - you could do a brushed finish which is quicker...
you will wish you had never started if you do this.. felt like this with my Cannondale m2000...
Posted : 12/01/2012 3:30 pm
Before....
After....
£25 done at a powder coaters [url= http://www.newtechpowder.co.uk/ ]HERE...[/url]
Quick buff up with a kitchen scouring pad after....walk in the park innit.
Posted : 12/01/2012 3:55 pm
^ looked better in white 😉
Posted : 12/01/2012 4:11 pm
Nitromors and elbow grease it is then.
It's not so much the colour I dislike it's the fact the paint jobs on Commies are generally quite poor and the chips and flaking is already really bad - looks very tatty after only a dozen or so rides. I only have to look at my Supreme and it starts to flake. I'm hoping that technique may help when stripping it but you know that as soon as I start the paint won't budge.
Posted : 12/01/2012 5:12 pm
Did my Ventana, but the paint came off very easily. Some can be a real task. Plenty of Nitrimors, some plastic scrapers. Tried polishing mine but gave up. If the frame has been lightly blasted before the original finish your looking at hours & hours of wet & dry flatting to get it anywhere near enough to polish. When polished it comes up a treat, but by christ is there some work in it. The kit I bought had 3 different mops & soaps. had it re-powder coated in the end.
Kayak23's looks nice, wish I'd have thought of that. 😉
Posted : 12/01/2012 5:55 pm
Try using a scalpel blade to take off most of the paint before using Nitromors.
Posted : 12/01/2012 6:14 pm
make sure you get the right nitromors.
Posted : 12/01/2012 8:06 pm
did my turner RFX with nitromors a scraper and wire wool to finish up the tubes. took about 8 hours to do the front. no paint or laquer needed afterwards. no problems at all, Turner even sell them like this from new.
Posted : 12/01/2012 8:45 pm
