Just wondering how people are setting up their Bloods. I'm having a bit of trouble getting a 'fast reacting and super supple rear end' as described by Orange. Its fine for single hits but I get bounced off the pedals a bit in the rough.
Think it needs a very firm shock pressure and a quick rebound, im currently running 190psi and 5 clicks from slow, compared to my five which is 170psi and 3 clicks from slow. Anyone running permanent propedal?
Also, I have managed to stop the rear mech cable from rubbing the guides but it looks like I will have to replace the outer every 2 or 3 months!
Bike Forum
[closed]
Orange Blood Setup
Posted 2 years ago #
Give Orange Tech department a call
Also give MOJO a call has you may need to change the Booster valve
to your wheight and style, cost about £ 28 quid.
Maybe come down a couple of clicks on the rebound and take a little
psi out of the shock.Posted 2 years ago # -
If you want the bike to be supple, then ramping up the shock pressure will probably not be the best idea. Have you checked you have 25-30% sag when sat on the bike in full riding gear. Setting sag is probably the first place i'd start, then rebound, then propedal.
Topic Closed
