Non Ust tryes used ...
[Closed] Non Ust tryes used with stans or other types
[#2109784]
Am converting my mates bike to stans and was wondering which non ust tyres people have used withbsuccess thanks, i am trying kenda block 8 but need something more grippy for winter
Posted : 21/10/2010 1:04 pm
kenda, maxxis, spesh all fine
Posted : 21/10/2010 1:08 pm
Nobby Nic, Racing Ralph, Dirty Dan, Kenda Excavator XC, Maxxis Advantage - all run tubeless with Stans no problem - none of them proper UST or tubeless ready tyres
Never got Kenda to work, but had success with Schwalbe, Bonty and Maxxis.
Posted : 21/10/2010 1:10 pm
just fitted MudX on Shimano UST rims, no problems
Posted : 21/10/2010 1:13 pm
NOT Panaracer.
Maxxis, Conti & Spesh all successful.
Spesh Eskar 2bliss is good at about £25.
Posted : 21/10/2010 1:14 pm
Nokian NBX / Gazza AM / Freddies Revenge
Continental Rubber Queen
Schwalbe Fat Albert / Muddy Mary GGC / Big Betty GGC
All worked fine. The MM and BB where the only ones that went up without a compressor though. With Schwalbe be sure not to use the UST tires on non-UST rims. New 2011 Schwalbes have a UST bead with normal casing so should be easier to pump up with a floor pump.
Posted : 21/10/2010 1:17 pm
I don't get it - you're asking for recs, so presumably going to buy these. Why not proper tubeless/ready ones ?
Small weight penalty vs far fewer failures IMO/E
Posted : 21/10/2010 1:28 pm
scaredypants - Member
not IME's. all the LUST versions i have used have failed. weak bead...
Posted : 21/10/2010 1:41 pm
Maybe we agree; it's the L in lust that's the prob there I reckon - trying to avoid the weight penalty by using thin/light stuff is a recipe for disaster
Posted : 21/10/2010 1:44 pm
I get on fine with various Kendas... Finally managed to rip one but it'd have done for a tube too so no worries there, every other one has been as good as you'd want. I've got some UST Nevegals and they've proved no better, just heavier.
My Minion still refuses to seal, but it's not terrible, it just slowly gasses out through the sidewalls so a few rides on it still goes flat overnight. 2-bliss Specialized aren't UST and don't have the weight penalty but work really well.
Posted : 21/10/2010 7:47 pm
I run Maxxis Ignitors, Panaracer Fire XCpro, Trailrakers and Mud pro, all ghetto tubeless with no issues.
Posted : 21/10/2010 7:59 pm
I have ran Maxxis High rollers, Nobby Nics, Mountain king and Racing Ralph tubeless on Olympics and Flows withoiut any issues. NNs can be a bit of a bitch to get air in without a compressor though (first time of inflating)
Posted : 21/10/2010 9:50 pm
I'm running maxxis advantage and crossmax tubeless with stans flow rims, works well.
Posted : 21/10/2010 9:53 pm
I've tried N/Nics as daveB said I needed a compressor to get them to seat.
Only prob I found with non-ust N/Nic was the sidewalls are thin and I ripped one on a descent in Coed, but would have happened if it was tubed so just poor tyre choice - ie it was an old tyre
Posted : 21/10/2010 9:55 pm
Happy with 2-bliss the captain tyres:- 2.2 s-works front and 2.0 control on the rear (cause I'm a bit of a fat git need the tougher sidewall on the rear 😳 ) works out quite a bit lighter/cheaper/just as good as using proper UST rubber IMHO. Also running bonty mud x's 29er Tubeless ready (TLR) plus stans sealant with great success!
Using this guys method ATM, works for me!
Posted : 21/10/2010 10:59 pm
[i]With Schwalbe be sure not to use the UST tires on non-UST rims. [/i]
Why? I do!
Posted : 22/10/2010 2:51 am
