Macro lens - how to...
[Closed] Macro lens - how to choose
[#2672891]
I've got a Lumix G1 camera which uses the Micro Four Thirds system. I'd like to get a macro lens but I've no idea how to choose. I'd also like to spend as little as possible without buying rubbish.
Any tips?
Thanks.
--Twirlip
Posted : 18/04/2011 3:30 pm
Macro filters rather than a true macro any good?
Posted : 18/04/2011 3:39 pm
What's your budget?
Posted : 18/04/2011 4:06 pm
yep, what's your budget? that will narrow your choice considerably
Posted : 18/04/2011 4:32 pm
m4/3 lenses aren't cheap and there's little in the way of second hand stuff so there won't be a budget option, so "as little as possible" may be a lot, unless...
You use an adapter and old manual focus lens route. m42 lenses for example. A 50mm f2 can be had for £10, and adapter for another £15 and a set of extension tubes for £5 and you'll have useful manual focus setup.
Or... you could use extension tubes on one of your existing lenes. I'd have thought the 20mm f1.7 plus tubes would be a good bet.
Posted : 18/04/2011 4:33 pm
No idea of budget really. I don't believe I can afford an full on macro lens. I'm looking for options before I decided to spend real money 🙂
Those extension tubes, do you have a link to them? I've googled about them but I'm not very familiar with photography and I'm not sure if I'm looking at the right stuff.
Thanks for all the responses!
Posted : 18/04/2011 4:55 pm
[url= http://cgi.ebay.co.uk/Macro-Extension-tube-for-Micro-4-3-M4-3-GF1-E-PL1-G2-G1_W0QQitemZ180595817511 ]m4/3 tubes[/url]
I've never tried m4/3 tubes so you'd want to do a bit of digging. But I have used m42 tubes [url= http://cgi.ebay.co.uk/New-UK-3-Steps-Macro-Extension-Tube-Ring-M42-Lens-/320622799878 ]like these[/url] with an [url= http://cgi.ebay.co.uk/M42-42mm-Lens-Micro-4-3-M4-3-M43-M-43-Mount-Adapter-/320551801037 ]m4/3 to m42 adapter[/url] and [url= http://cgi.ebay.co.uk/QUALITY-HELIOS-58mm-F2-LENS-M42mm-SCREW-MOUNT-/360356438833 ]m42 lens[/url] which works well.
Posted : 18/04/2011 5:04 pm
Whatever you buy just make sure you look real closely at it first....
IGMC
Posted : 18/04/2011 5:22 pm
I got normal 4/3 35mm macro for £180, many around for £200 now.
Posted : 18/04/2011 7:25 pm
