lubricant for forks...
[Closed] lubricant for forks ?
[#1085717]
does anybody use any kind af spray lubricant on forks..... (no i dont btw)..... just wondering as (i hadnt been on the bike for 3 weeks...but went on it today and the forks were a little juddery at first..
Posted : 29/11/2009 10:24 pm
 Olly
bit of a squirt of dry lube or GT85 makes them last longer and feel plusher for sure.
but if theyve been standing for a while, all the oil will be in the bottom, and they wont work properly till its sloshed up a bit.
Posted : 29/11/2009 10:27 pm
 jim
Silicone spray seems to work well for me.
Try Fork Juice spray. I use it regularly to lube the fork stanchions and so far I am quite impressed.
iRideSpesh
Posted : 29/11/2009 10:29 pm
I put a small amount of fork oil on the stanchions before riding and cycle the forks thru a couple of times then wipe off any excess around the seals.
That's for an oil fork tho (Fox vanilla)...
Posted : 29/11/2009 10:31 pm
flip your bike over for half an hour and the oil will travel to the seals and keep them moist. just once a week should do it, fork juice is good too.
joe x
Posted : 29/11/2009 10:34 pm
TF recommend any lube with Teflon. Some chain lubes have that. Just to be "perfect" I use proper Sendtec fork oil that I drip onto the seals with a neat little "Pen oiler". I let it soak in and just before the ride compress the fork a few times and wipe the stanchions with a rag to remove dirt trapped under the seals.
These precision oilers can be bought at car accesory stores for just a few quid and make adding a couple of drops of oil very easy. If you do that every ride it makes a big difference to performance and extends service interval.
Posted : 29/11/2009 10:36 pm
