You never know but i'll ask, is there anyone on here who knows about seimens s7 controllers and specifically if you have the step 7 software, i'm having a bit of a nightmare with the MMC card etc. we are based in chester but id travel a reasonable distance if there is anyone who can help!!
Last time I worked with Seimens, it was S5..so can't really help. Does this provide any pointers....
As above I only have previous with S5 and over the past decade have mostly used GEM80.
Siemens are only up the road in Manchester so might be worth a call?
Siemens PLC, Manchester
Siemens IA&DT, Manchester
UK Technical Support
Sir William Siemens House; Princess Road
M20 2UR Manchester, United Kingdom
Tel +44 161 446 5545
Fax +44 161 446 5522
Service-Support.ad.uk@Siemens.com
Cheers guys, i've downloaded s7 lite so am going to work on it from that angle first although as with most industrial computers it not a case of plug and play!!!.
GEM80
Now that's old skool...remember the 'portable' programming terminals 😀
What problem are you having.....I have used S7 a lot in the past but a bit rusty at present, still might remember some of the problems we had....also still have all the manuals for reference and S7 controllers on site at present
I work - as IT, not engineering - in a very reputable automation control consultancy..
We're based in Blackburn (bit of Google-fu will find us easily).
Drop me a mail (in profile) and I'll ask an Engineer...
