how do you know if you need long or medium? and whats the difference? other than the obvious!! length.
my rear mech is goosed and i am not sure which i need for my orange 5?
any help appreciated.
Bike Forum
[closed]
long cage / med cage xt rear mech!
Posted 1 year ago #
If you've got a triple ring front set up with a normal (not road) 11-32 or similar rear cassette, you need a long cage.
Posted 1 year ago # -
Perfect text book answer...however if you're disciplined with your gears and avoid the extreme combinations of gear (small chainring/small sprocket or large chainring/large sprocket), as you should anyway, a medium is sufficient and you gain a bit of chain tension and the mech is a little less vulnerable.
Alaric.
Posted 1 year ago #
Topic Closed
