led gurus!!!! give ...
[Closed] led gurus!!!! give me a hand.....
[#949870]
right ive got this hid light ......
http://www.singletrackworld.com/forum/topic/fs-solstice-50-hid-li-ion-light-2
and i want to convert it to leds as the bulb is failing a bit!!
what do i need and will it be easy to do??
i think the battery is in quite good shape so can possibly use it.
is it cost effecient to do or should i run it untill it breaks and then get a dx light??
cheers
steve
Posted : 13/10/2009 10:02 pm
take the lense off the lamp very carefully (there not an air seal unit so don't panic) and give it a wipe and stick it back on, be as good as new. A misted HID is not the end of the world, it only needs a clean.
Though I'd be interested in being pointing towards some simple DIY LED info
Posted : 13/10/2009 10:08 pm
if its 13 v a triple is the best bet - so you need a triple led and the power supply - the taskled bflex is the best IMO
http://www.cutter.com.au/proddetail.php?prod=cut757
You need to check that you have the physical room for the 35 mm pcb (MR11) andd that the pcb is mounted in such a way as to transmit the heat to the casing.
Posted : 13/10/2009 10:11 pm
tried taking lense cap off but bulb is sealed unit!!
Posted : 13/10/2009 10:15 pm
will the cutter kit give me any more light out put??
Posted : 13/10/2009 10:20 pm
[i]But[/i] HID lamps are not air sealed, apparently you cut off the lense with a craft knife, though not sure how you can 'glue' it back on as some-one used superglue and it damaged the reflector, would it just sit in place when back together?
IIRC Lumicycle used to offer this as a service...
Cutter triple will be around the same light and the same battery life as a hid I think - depending of course on what the HID is
Posted : 13/10/2009 10:22 pm
arent the bulbs full of gas??
Posted : 13/10/2009 10:23 pm
so how do i go about getting over a 1000 lumen then?? i want a light better than my mates hope visonled thing
Posted : 13/10/2009 10:25 pm
I have cleaned my old Hope Hid a few times now. just re-sealing it with a dab of silicone sealant. The rubber overall seal keeps it all together.
Cleaning the lense and reflector does improve the light to how it was.
i think there are bits of reflector peeling off tbh
Posted : 13/10/2009 10:29 pm
The bulb is full of gas, but it is the lense of the reflector that will have misted up. I have cleaned mine up in the past, I think I used some sort of clear high temp sealant I got from Halfords to re-seal.
arghh! 8)
doh the bulb is sealed !! you are just on about the reflector
Posted : 13/10/2009 10:33 pm
renton - Member
You want the triple xpg led then! 35mm if it'll fit, with the SS cute optic (narrow)
Posted : 13/10/2009 10:36 pm
kinda666 have you got any links on what i need to order exactly for that lot then??
cheers
steve
Posted : 13/10/2009 10:38 pm
Renton - a quad of the latest crees will be approaching 1000 lumen in theory - in practice it will be less.
I am not sure if you can run a quad from that battery - a quad needs 14.8 v ish - a buck driver needs at least one more so needs almost 16 v minimum from the battery. A boost driver needs one less v - so must be under 13.5 volt maximum- so it depends on the battery voltage.
I am sure the triple will work as that with a buck driver only needs12.1 volt minimum
the other option would be to use a MCE kit - that needs different drivers depending how the dies are wired up.
Have a look on candlepower forums for more info.
You will do well to beat an HID with homemade LED conversions - but a quad should do it if you can get it to run.
Read up on the cutter site as well.
Posted : 13/10/2009 10:39 pm
cheers tj!!
Posted : 13/10/2009 10:41 pm
Just an update......
ive managed to take the bulb out of my light and then the lense off the bulb .
you would not believe how much shit come off the reflector!!! it looks new again 😀
cant wait to try it out and see how much light it has give me back
Posted : 15/10/2009 9:33 pm
