kona cindercone - w...
[Closed] kona cindercone - worth restoring?
 aw
[#593107]
I have an old kona cindercone 97 18"
The bike has been converted to single speed with the use of a chain tensioner. The steel frame is damaged in several places with the usual cable rubs and chain damage on the stays. I think the frame needs a respray.
The wheels, brakes and other kit are not that special and probably could be upgraded but is all of this worth it?
I really enjoy riding the bike (as it it stands now) but I could buy a dialled prince albert or a cotic simple for instance for less than £1k?
I will post varous pictures and a detailed spec shortly.
I would really value the forum's collective opinion on this one 🙂
Thanks in advance...
Posted : 31/05/2009 8:56 am
 aw
First the whole bike 🙂
Posted : 31/05/2009 9:09 am
It ay be a bit mmodern but you'll get a lot of help if you ask on
[url= http://www.retrobike.co.uk/ ][b]retrobike.co.uk/[/b][/url]
A fountain of knowledge awaits you there,
Posted : 31/05/2009 9:12 am
 Bez
unless you have a burning need for disc brakes or suspension, just ride the thing and replace stuff as it wears out - spunking £1k on a very similar bike is just going to leave you wondering if it was worth it
'needs' a respray? doubt it - 'looks a bit tatty' maybe, same as any bike will after a while
Posted : 31/05/2009 9:19 am
looks fine to me, apart from that 'shopper' stem.
Posted : 31/05/2009 9:21 am
what they said - Inc the stem
You could cost up discs and sliding dropouts, if you really like the bike and will keep riding it.
Posted : 31/05/2009 9:42 am
It looks like a fun bike!
If you wanted to upgrade the braking you could get a disc fork (and wheel, and brake etc)
And I wouldn't worry about respraying it etc. It'll never be a museum piece, so just ride it!
Posted : 31/05/2009 10:15 am
 aw
The frame is a little damaged...
Here is some of the [s]highlights[/s] lowlights 🙂
Posted : 31/05/2009 8:37 pm
if you want a respray, get a respray.
Posted : 31/05/2009 8:45 pm
 aw
any idea of price etc?
Posted : 31/05/2009 8:48 pm
 aw
any other ideas on upgrades for this bike...the wheels are a mismatch of Mavic 221s on the rear with a shimano deore hub and Mavic 238s on the front with an unnamed hub.
Forks are P2s
Tyres I have just replaced with Kenda Blue grooves
Cranks are Raceface ride XC
Saddle is a Flyte
bars are Raceface flat
brakes are avid Vs
Posted : 31/05/2009 8:52 pm
just ride it, don't get it resprayed, it works for you and must have done for a long time maybe get ceramic rims and poncier v's next time you wear your rims out
Posted : 31/05/2009 8:58 pm
fix it up but too a budget, get second hand bits of classifieds and touch the paint up with a car touch up pen. just take it into halfords and match up. looks a little old but so what, will look much better after a bit of tlc. ENJOY
Posted : 31/05/2009 9:00 pm
 Bez
http://www.bobjacksoncycles.co.uk/resprays_pl.php
wheels? lx hubs on xm719, sorted
Posted : 31/05/2009 9:01 pm
I'd recommend superstar v brake pads - i love them. just put new cables etc on it and she'll be running sweet in no time.
Posted : 31/05/2009 9:02 pm
Worth keeping it going, yes
Worth a respray possibly
wortk real work like disc mounts and sliding dop outs? IMHO the cost of the work is to close to a new frame. Unless you want to keep it going
Posted : 31/05/2009 9:13 pm
 aw
Yes I have had it since 1999...we have done the south downs together three times to name but a few rides...
I have some of those stickers for rub points etc so I could use those to patch up the paint work.
The stem looks weird but works. I will try to put back the original which was less extreme 🙂
Posted : 31/05/2009 9:48 pm
 aw
Thanks Bez - not bad price 🙂
I would like to keep the original colour but I probably got no chance matching it 🙁
Posted : 31/05/2009 9:51 pm
colour match no probs.
If you are rrspraying and getting new wheels you'd be silly IMO not to get disc mounts abs sliding dropouts
Posted : 31/05/2009 9:54 pm
I've got one of those still going, and it's in a much worse state... had 2 visits to the welders and is partly primed, partly painted. Still running well with drop bars, slicks and mudguards as a poor weather commuter.
I'd not worry about the respray, get some touch up paint for it (Car places will do there best to colour match).
With a small amount of filing to the dropouts, you can run 32-16 without a tensioner on the 19" version of the '97 frame so I assume that the same trick will work for an 18" version.
Posted : 31/05/2009 10:11 pm
Not worth restoring. Let it die in style - ride it into a tree.
Posted : 31/05/2009 11:10 pm
 aw
I will ignore that last comment Shame-He-Likes-Bikes!
How do you do that then Paule?
Posted : 01/06/2009 8:28 pm
 Bez
Er. You get a file and you file the dropouts. Effectively shortening the stays.
Be sure it'll work before you do it, though. Magic ratios vary on Konas (I have had 34:17 work on three of mine - one perfectly, two with filing - and 32:16 has never been even close to working).
Posted : 01/06/2009 10:04 pm
Whereas I got 32:16 to work perfectly on an 18" frame (1994 Cindercone) and a standard 1/8 chain. All without filing (by me at least. It had 4 owners on retrobike before me).
Posted : 01/06/2009 10:39 pm
leave it on the beach, after riding it into a tree of course....
[img] ?v=0[/img]
Posted : 01/06/2009 10:44 pm
AW, you have too much time and money. Why don't you spend both on [b]sex and drugs, and rock'n'roll[/b]? The bike looks fine, ride it or not it won't be worse than a £1k modern thing (and that's a lot of drink in my books).
[i]Or just send it to me, I'll pay for the courier.[/i]
Posted : 01/06/2009 10:50 pm
