Viewing 40 posts - 1 through 40 (of 177 total)
  • IOS 11
  • imnotverygood
    How do I stop it from auto updating on my iPhone.
    Ta
    Wrong forum 🙁
    bikebouy
    Is it out then ??
    mrmo
    yes, although i have been using the GM for a few days
    It’s been out about 10 minutes.
    somouk
    I’ve been using the GM since it was released to developers last week. No issues which was a nice surprise.
    bikebouy
    Ah, cheers.. I shall wait until back in UK to update.
    Chrz
    Jamie
    igm
    Is it an actual upgrade or just a biggerer number?
    Big upgrade too not just going all the way to 11.
    igm
    Oooh nice reference. And my iPhone is black too.
    GrahamS
    BEFORE YOU UPDATE:
    Go to Settings->General->About->Applications
    And read the list of apps you currently have installed that are NOT compatible with iOS11 or will make it run slowly.
    38 on my list at the moment. I’ll hold off for a bit (I always do anyway).
    kelron
    Just a heads up, the beta version of 11 is noticeably slower than 10 on my iPhone 6, no idea if it’s a widespread issue or if the release version will be the same.
    Jamie
    The latest beta is the GM. So will be the same as what came out today.
    Ooooh! Shiny.
    All the apps I use regular all updated, plus I stopped worry too much about waiting as they update any major issues quickly after long test periods it’s nearly always stable.
    P-Jay
    Despite saying many times I wouldn’t, I’ve drived in with iOS11 (and TVOS11 when I get 5).
    Good luck everyone!
    deadlydarcy
    Only 5 for me Gee – none of which I recognised anyway. Onbviously a few of those that got downloaded, used once or twice then consigned to the last screen 😆
    You’re using an iPhone3GS aren’t you? 🙂
    dirtyrider
    i don’t even use 38 apps, never mind having 38 that will be out of date
    is there more than 15/20 apps worth using?
    scc999
    I’m pretty sure I read that this version wont support any 32 bit apps – so if you are still using those then the will never be supported on iOS 11. Probably not a big isue for most peopole though.
    deadlydarcy
    I dunno…some people have 37 of those.
    2 here out of 171 which is amazong as I didn’t even know I had that many. The 2 dodgy ones I’ve not used it a very long time.
    nealglover
    amazong
    Is that the next level up from Prime ?
    It’s the new zomg!
    P-Jay
    I like the new flip up menu and my Apple TV has stopped making my speakers buzz so I’m happy so far.
    Yup the taskbar is pretty cool. I’ll be testing drag and drop tomorrow when I’m training.
    GrahamS
    Granted most of my 38 out-of-date apps I wouldn’t miss that much (mostly occasional games and stuff to keep the kids amused) but some I’d quite like to keep:
    SynthCam – takes nice synthesised shallow focus and tilt-shift photos by combining multi angle shots
    MAVideo – motion-activated video recorder. Useful sometimes.
    OSMTrack – used to records GPS traces for OpenStreetMap
    Pushpin – used to edit POI for OpenStreetMap
    SnowForecast – ski reports
    Civilisation Revolution – mobile version of Civ (good for long flights etc)
    Gourmet Society – quick look up of restaurants where the card is valid
    PlayTales – interactive stories for the kids
    Humax Remote – for when I can’t find the real one
    Met Office – for the weather obv
    BLE Utility/nRF UART/nRF Utility – Bluetooth diagnostics stuff that I use for work to test Bluetooth, simulate BLE devices etc
    Resistor – nice simple resistor decoder
    Skyfire – my secondary browser of choice for gentleman’s pursuits
    deadlydarcy
    Are you sure you can go to iOS11 on yours Gee?
    jambalaya
    Like it so far, had to reduce the text size but new fonts are bold and clear 🙂 a few older apps don’t work but very rarely used them anyway, “retro” phone signal strength graphic !
    GrahamS
    Yeah I finally relented and upgraded my venerable 4S to an SE 64GB.
    CountZero
    I’ve got probably that many navigation and mapping apps!then there’s several ereader apps, the photography apps…
    jambalaya
    Some comments on the new file system app
    https://www.macrumors.com/how-to/files-app-ios-11/
    Kryton57
    So its good then?
    Mine says MyFitnessPal wont work so thats a deal breaker for me.
    allthegear
    If you have an app that has not been compiled with a 64bit binary then it must be really quite neglected by the developer by now.
    Rachel
    Jamie
    @Kryton
    I’m running iOS 11 and MFP seems to work ok.
    deviant
    Works fine on my SE but appears to be a massive battery drain.
    If I’m light on use at work I usually go home with 70-80% battery left, I’ve been at work half an hour so far and I’m down to 90% already, not looking good.
    slowoldman
    Only one dodgy app here. Need to find a new metronome.
    Jamie
    @deviant.
    I had the same. What you will probably see is the battery dive off a cliff then stop at 3/4% for several hours (5 in my case). I think it’s just the battery recalibrating. I let mine run till it died, full charge over night and will see what happens today.
    SE as well.
    maccruiskeen
    Theres also often a lot of background tasks going on for quite some time after an upgrade
    Jamie
    That would explain an increase of usage, but not the misreporting of battery life. That’s a calibration issue which should self right itself after a full discharge/charge.
    Hopefully.
    nickhit3
    re battery issues – as an example, the action centre toggle does NOT disable bluetooth if you find that re enabled upon updating as I did despite never using bluetooth products)- go into settings and you’ll find it still on. Its worth googling/ youtubing battery tips for ios11- I’ve always done that and there’s a bunch of things to turn off that you genuinely don’t need (looking at you ad tracking location etc) take a moment and look them up, you’ll be surprised what is running you don’t need. And no, it doesn’t cripple the phone. Never found anything unusable after turning the majority of location and background tasks off etc.
    Battery calibration is NOT the solution, unless your phone is only 24 hours old. Proactively look up the tasks that use battery resources and turn them off.
The topic ‘IOS 11’ is closed to new replies.
